The replacement chuck and taps finally arrived (Thank you Rotagrip
) So I could continue with the backplates.
The bore was drilled 6mm then 12mm and bored out to 13mm. There is a 4mm deep 14mm counterbore to match the RT adaptor. I decided to start the thread with a singlepoint tool and just use the taps for finishing. On the first screwcutting pass there was a crack and the tool flipped over, maybe 0.2mm was too deep
The point on the tool had chipped off so I roughly reground it by hand and had another go, this time with a cut of 0.1mm. This worked so I cut to a depth of 0.3 mm and then finished of with the taps.
I went to repeat this for the second backplate but during drilling 12mm the drill snatched violently and went off center. I withdrew the drill and there was a large blowhole
I will need to get another slice cut and start again.
I then put one of the MT2 -M14x1 adaptors in the lathe and finished the chuck face. Just 4 M8 threads to do.
