Author Topic: Welding Cart Build  (Read 3442 times)
Offline Joco
Welding Cart Build
« on: November 23, 2016, 08:21:29 PM »
Another of the workshop projects to help get things all organised is a welding cart.  This build started a while ago and has taken a back seat while the Lathe stand was completed and commissioned.
Current status is:
1. frame built
2. mounting plates for the wheels are drilled and welding in place with a successful trial fit of wheels done
3. bottle shelf has angle steel supports welded in place and a success trial fit of the gas bottle performed to prove the shelf is the correct width
4. bracing triangles to help hold the gas bottle in place designed and cut but work has gotten in the way of progressing those this week
See the pics below.
Pic 1:  Over all view of the cart
Pic 2:  The bottle shelf
Pic 3:  The "crown" on the top shelf that will provide convenient places to loop earth and torch cables over
James
Wellington - NZ
Offline Joco
Welding Cart Build
« Reply #1 on: December 03, 2016, 09:47:23 AM »
The welding cart continues. I have everything pretty much fabricated that I need to its now painting time. Pity the paint takes 16 hours to cure between coats. A real pain. However I have a first coat done and things are very YELLOW!
James
Wellington - NZ
Offline Johnmcc69
  • Erie Pa., USA
Re: Welding Cart Build
« Reply #2 on: December 03, 2016, 05:08:27 PM »
Nice work! It certainly looks very sturdy!
« Reply #3 on: December 03, 2016, 03:17:17 PM »
At least it will be easy to find though  ;) Looks good and sturdy!!
Offline Joco
« Reply #4 on: December 03, 2016, 09:31:39 PM »
Yup shes really solid.   When putting the lathe on its stand this was laid on its side with the pallet on top to act as a temporary riser while we shortened up the hoist to get the necessary height.
It had 280 kg sitting on for a bit. Another piece of "brick shithouse" engineering by "Walker Engineering Inc".   :Jester:
James
Wellington - NZ
Offline Joco
Welding Cart Build - Wheels on and shelves
« Reply #5 on: December 07, 2016, 11:53:48 AM »
Okay after much spray painting here is the cart with wheels on and the top and middle shelves just laid on the frame.  I need to take some nicks out of the edges where the welding beads are so the shelves sit nice and flush the frame. I also need to source a bottom shelf. But no major rush for that.
On the whole not looking too shabby.
James
Wellington - NZ
« Reply #6 on: December 08, 2016, 12:55:13 AM »
Now that's one sweet cart  :ThumbsUp: :ThumbsUp:. Captain Jerry should love the colour,  looks like Cattypillar Yeller   8)
Cletus
Offline Joco
Welding Cart - ready for action
« Reply #7 on: December 09, 2016, 09:27:38 PM »
Its done, well mostly, predominately done. Done enough that it can be used.   :ThumbsUp:
James
Wellington - NZ
Offline bruedney
  • Wellington, New Zealand
« Reply #8 on: December 09, 2016, 11:43:29 PM »
Nice
And that is a nice little pile of steel on the floor
Have a good one
Bruce
