An interesting book about an interesting man. It is available from Camden Publishing in UK.
Yes it is and it gets a second recommendation from me
- I particularly liked his swash plate motors
There is a photo of the Redrup 'reactionless' engine.
It looks to me like it used a bevel geared differential (like the Siemens engine) at the rear of the engine :
i.e. the engine crank-casing has one bevelled pinion (with a bearing into the fixed casing) through which, passes the crank-shaft to the second, rear, pinion with the crank-shaft bearing to the fixed casing.
The two pinions are flanked by bevel gears running on shafts fixed to the fixed-casing.
The prop mounts to the front of the crank case (thus running at half engine speed)
