If you have your mill bolted to a base board, you would need to unbolt it to get at the bolts that hold the column to the base, or at least have holes in the baseboard to get at them through. I don't see how it would help with height limits, could allow wider parts though.
Jim,http://sherline.com/Wordpress/wp-content/uploads/2015/12/6100inst.pdfis the instructions. From that, you would just use the horizontal conversion base as the mounting board. From the instructions, the mill can be either mounted in the normal vertical position or in one of two horizontal positions.Alan
Looking great! Did I miss where you made the Teflon rings? How was that done? Never tried them, interested to see how they work out.
Quote from: crueby on December 06, 2016, 05:13:35 AMLooking great! Did I miss where you made the Teflon rings? How was that done? Never tried them, interested to see how they work out. They came with the kit Chris. Might be tricky to make the right size.How did your pool night go? Jim
This is very valuable, Jim. Thank you for your detailed documentation.How do you like the ER16 collet chuck/adapter? Is that the one sold for the Taig lathe?~Hans
