Author Topic: Freelance Inline Twin  (Read 54529 times)
Offline yogi
  • Duncannon, PA USA
    • Yogi's Workshop
Re: Freelance Inline Twin
« Reply #75 on: March 25, 2017, 11:32:41 PM »
Thank you guys for the kind comments! It's very much appreciated.  :cheers:
Perry, the lap I'm using is an Acrolap. The one I have is about 0.05 mm under size. I don't know how far the lap will expand. I had one expanded about 0.2 mm over nominal. It started to get quite "barrel" shape, only cutting in the middle half of the lap. Not ideal, but it worked. They are brass, and can be turned down to whatever size you need.
Brian, the crank pin is locked between the outer crank disc assemblies, which are then located between the front and rear covers. This secures the whole crank assembly axial in the crankcase. The crank assembly is "self aligning". The disc assemblies are allowed to rotate on the crank pin to find their alignment, and once installed in the case, it can't move any more. I have a section view in the first post, that will help to illustrate. I hope I answered your question.
Thank you for your interest in my project,
Yogi
« Reply #76 on: March 26, 2017, 12:03:56 AM »
Very clever design, Yogi. I looked at that section view the first time around, and missed that.---Brian
toolznthings
« Reply #77 on: March 26, 2017, 12:57:11 AM »
Looking good !  :ThumbsUp:
Offline yogi
  • Duncannon, PA USA
    • Yogi's Workshop
« Reply #78 on: April 20, 2017, 12:47:01 AM »
Hello everyone, it's time for an update. Up next, the pistons:
I started with turning a boss to hold the blank in a collet for the subsequent operations. The piston diameter is 32mm, too large to go directly into a 5C collet.
Chucked in a collet, the OD is turned to finish size and the grooves for the rings are cut:
Using a collet block, it is over to the mill to cut the recess for the connecting rod:
Without removing the piston blank from the collet block, the cross hole is drilled and reamed. This ensures the hole is perfectly perpendicular to the milled recess.
The last operation is to turn off the chucking boss. The piston is clamped very gently in the 3 jaw chuck with some paper to protect the surface from getting marked up.
The finished Pistons:
Thanks for following along, and stay tuned...
Yogi
« Reply #79 on: April 20, 2017, 12:50:19 AM »
I always dread seeing your posts Yogi. Your parts always look so...so...'finished'.  :ThumbsUp:
« Reply #80 on: April 20, 2017, 01:02:32 AM »
Nicely done Yogi!
Offline yogi
  • Duncannon, PA USA
    • Yogi's Workshop
« Reply #81 on: April 23, 2017, 03:00:56 PM »
Thank you Dave and Zee for the kind comments! It's very much appreciated.  :cheers:
I have a number of components finished and felt it's time to assemble what I have. I don't want to get too far ahead of myself, making parts. If there is a problem, it would be easier addressed now rather than later. And it's always exiting to see an engine taking shape...
A plug is inserted in the camshaft bore to close it off on the back of the engine.
The crankshaft is finished up on the accessory end with a small diameter shaft extension.
The gear installed on the crankshaft:
The connecting rods are assembled with the pistons and needle roller bearings:
The assembled crankshaft is installed and the crankcase closed.
And the assembled engine block:
To give you an idea of the size of the engine, here with yours truly.
I'm very pleased how the engine has turned out so far. Everything is fitting together and works the way I envisioned it when I designed it. I haven't discovered any design flaws (yet).  8)
Thank you for following along, and stay tuned for more.
Yogi
« Reply #82 on: April 23, 2017, 05:46:07 PM »
Looks wonderful  :praise2:  :praise2: What's the machine behind you in the last picture? CNC Deckel?
Offline stevehuckss396
  • Sterling Heights, MI USA
« Reply #83 on: April 23, 2017, 09:56:58 PM »
I agree, looks wonderful. Thanks for sharing.
« Reply #84 on: April 23, 2017, 11:20:58 PM »
Beautiful work Yogi!!  Nice to see your mug too  :D
Offline yogi
  • Duncannon, PA USA
    • Yogi's Workshop
« Reply #85 on: April 24, 2017, 12:45:00 AM »
Thank you gentleman for the kind comments!  :cheers:
Roger, the machine is a Maho MH500 CNC mill.
Bill, I couldn't get the grin off of my face, so my wife made me post it...  :embarassed:
« Reply #86 on: April 24, 2017, 12:45:11 AM »
Very nice Yogi!
I really like the ball bearing supported crankshaft.
Offline yogi
  • Duncannon, PA USA
    • Yogi's Workshop
« Reply #87 on: April 25, 2017, 12:41:44 AM »
Thank you Dave!
I'm very pleased how the crankshaft turned out. It's very low friction. I hope this will materialize in the running characteristic of the engine. I tried to take a short clip of me turning the engine over to demonstrate.
I have already ideas of future engines with this kind of crankshaft.
<a href="https://www.youtube.com/watch?v=ps3SC21VXn0" target="_blank">http://www.youtube.com/watch?v=ps3SC21VXn0</a>
« Reply #88 on: April 25, 2017, 11:05:34 AM »
 :ThumbsUp: Wow.
I saw the earlier picture of you. Nice to meet you.  ;D
toolznthings
« Reply #89 on: April 29, 2017, 05:03:00 PM »
I'm up to date on your posts now. Great work as always !!  :ThumbsUp:
