Author Topic: Floating Reamer Holders  (Read 12841 times)
Re: Floating Reamer Holders
« Reply #30 on: July 01, 2017, 03:29:09 PM »
I got back on this again as I need to get on with the fuel pump and injector for the two stroke diesel. I looked up the manufacturers site for the Magafor reamers I am using. The figures for a 2mm reamer suggest ~2400rpm and a feed of 0.1 - 0.15 mm per rev. My lathe can achieve 2000 rpm and has fine feeds of 0.08 and 0.16 mm per rev. I decided on 0.08mm per rev. I also purchased new Titex drills in 1.8, 1.85 and 1.9 mm diameters. For these trials I didn't power feed the reamer but just followed the carriage by eye. The feed was much slower than I have been using previously.
All trials used the same 1.95mm H7 reamer
1st Trial
Center drill without countersink. 1.85mm dia. drill. Reamer held in a normal chuck.
1.96mm pin gauge passes through
1.97mm pin gauge enters ~5mm from the start end and ~2 mm from the exit end.
1.98mm pin gauge enters ~2mm from the start end
2nd Trial
As above but using the floating reamer holder. The reamer was difficult to start in the hole.
1.97mm pin gauge enters ~2mm from the start end but not from the exit end
1.98mm pin gauge no go
3rd Trial
As above but with a countersink from the center drill.
1.97mm pin gauge enters ~1mm from the start end but not from the exit end
4th Trial
As above but 1.8mm drill. More force was required to feed the reamer.
1.97mm pin gauge enters ~3mm from the start end but not from the exit end
1.98mm pin gauge enters ~1mm from the start end
5th Trial
As above but 1.9mm drill.
The hole was over 1.95mm so the reamer passed through without cutting.
Conclusion:
Following the manufacturers recommendations helps. The floating reamer holder greatly reduces bell mouthing.
« Last Edit: July 01, 2017, 07:50:38 PM by Roger B »
« Reply #31 on: July 01, 2017, 08:35:56 PM »
Nice to see that you are moving forward  :ThumbsUp:
