Author Topic: Bruce's Rupnow Engine Build  (Read 11830 times)
Offline bruedney
  • Wellington, New Zealand
« on: November 01, 2016, 07:58:13 AM »
Well after a number of weeks of waiting for the MT2 reamer from the UK to fix up my mill spindle (Thanks Arc Euro for Fedex backup) I have finally started making swarf again.
The weeks were productive though with all of Brian's drawings redrawn in metric.
So today I made a con rod
Measure twice - cut once the saying goes
The "practice" version was profiled in 10mm aluminium  :facepalm:
Then I got the mill working on the real piece
The final version all cut out
And with some bushes fitted
This engine is a lot smaller than it looks.
Thanks Brian for the design and the drawings
Bruce
Offline Joco
Re: Bruce's Rupnow Engine Build
« Reply #1 on: November 01, 2016, 09:52:48 AM »
Nice!    :popcorn:
James
Wellington - NZ
« Reply #2 on: November 01, 2016, 11:54:48 AM »
Hi Bruce--I am thrilled to see you on board with my engine. Yours will be the fourth build that I am following. It is a great engine, and you will probably get many requests for the plans in metric. Good luck,--Brian rupnow
Offline Imagineering
« Reply #3 on: November 03, 2016, 08:50:38 AM »
Have it ready by Railex Bruce?
Offline bruedney
« Reply #4 on: November 03, 2016, 09:02:37 AM »
Yeah right
Need to get some CI and a few blocks of ali first
Offline bruedney
« Reply #5 on: November 09, 2016, 12:48:14 AM »
A little bit more done in the last couple of days
I have repurposed this
Into this
Here are a couple of machining shots
Bruce
« Last Edit: November 11, 2016, 07:10:39 PM by bruedney »
« Reply #6 on: November 09, 2016, 01:08:21 AM »
Very nice. I am following closely. Thank you for the progress report.---Brian
Offline bruedney
« Reply #7 on: November 10, 2016, 06:51:38 AM »
A little more done
Crank web and con rod, pin and retainer done.
Also cut a big block of expensive ali (7075 - I think) down for the frame and cylinder mount. That took quite some time.
Thanks for looking in
Bruce
« Last Edit: November 11, 2016, 07:11:27 PM by bruedney »
« Reply #8 on: November 10, 2016, 09:08:47 AM »
Bruce, a couple of your photos are not showing.  There is one in post 5 and the lastest one in post 7.
Offline bruedney
« Reply #9 on: November 10, 2016, 06:11:35 PM »
Thanks Vince
Fixed #5 - I can see # 7 (there is only one)
Bruce
Offline bruedney
« Reply #10 on: November 11, 2016, 05:50:31 PM »
There seems to be something happening to 2 of the photos above. They were taken using my phone and I am going to try replacing them with ones using my camera.
Bruce
 Edit: Photos changed - Let's see if that works
« Last Edit: November 11, 2016, 07:12:18 PM by bruedney »
« Reply #11 on: November 11, 2016, 09:23:47 PM »
Can see the missing photos now.
Offline bruedney
« Reply #12 on: December 01, 2016, 09:49:56 AM »
Things have been a bit busy of late but I have made some progress.
The big chunk of Ali has been sized and then shaped
I need to get a long reach end mill to hog out the gap in the frame so I thought I would move on to the cylinder
After cleaning up the Cast iron and turning to size I decided to cut the fins before boring the cylinder out
After drilling out to 18mm I got to start using my new 12mm Boring Bar - It worked well - ran out of time so have only got to 21mm.
I am away for until the middle of next week so I may not get too much more done until then.
Bruce
« Reply #13 on: December 01, 2016, 03:16:58 PM »
Any progress is good progress. I am watching this thread every day, looking for the third running Rupnow engine.---Brian
Offline roboguy
« Reply #14 on: December 01, 2016, 06:13:37 PM »
Nice work Bruce! Will you make the HVMES meeting this week?
Sent from my SM-G920I using Tapatalk
Offline bruedney
« Reply #15 on: December 07, 2016, 08:49:21 AM »
Thanks James
As you will have seen, no I wasn't at the meeting. My wife is heading down to Kaikoura early tomorrow morning to provide support with work so I decided to stay home with her.
I did get a little machining done though.
Major machining on the cylinder all done. Just need to set it up on the mill to drill and tap all the holes
Bruce
Offline Joco
« Reply #16 on: December 07, 2016, 11:29:04 AM »
The fins look to have come out rather well.
James
Wellington - NZ
« Reply #17 on: December 08, 2016, 01:28:56 AM »
Nicer fins than most fish have!!!!
Offline bruedney
« Reply #18 on: December 08, 2016, 10:41:02 AM »
Workshop night - Wife is away for 6 days with work so I got to do a far bit of swarf making tonight
Mounted the 3 jaw on the mill (poor man's rotary table - not a big deal with CNC) and centred the cylinder and drilled and tapped the holes on both ends
Then I chucked up a piece of tooling ali in the 4 jaw and started the piston.
Part way through though I found that the carriage on my lathe was lifting. So I stripped the cross slide off and skimmed a bit of the carriage gibs to remove the play. Much nicer
Here is the piston ready for some milling and drilling operations tomorrow night.
Bruce
Offline bruedney
« Reply #19 on: December 10, 2016, 10:29:59 AM »
"Well the best laid plans of mice and men"
My plan was to spend heaps of time in the WS due to the boss being away. But work has got in the way to a certain extent.
But I got a bit done this evening.
Got the piston all set up to drill the wrist pin hole and then turn 90 deg and machined the slot and grub screw hole.
Then machined the wrist pin and fitted it all together
It is starting to look a bit like an engine  :whoohoo:
Bruce
« Reply #20 on: December 10, 2016, 03:19:15 PM »
Nice stuff, Bruce. that was a good plan, leaving the square shank in place in order to get the internal slot at 90 degrees to the wrist pin hole.---brian
Offline bruedney
« Reply #21 on: December 12, 2016, 08:55:59 AM »
Hi everyone
Made a start of the cylinder mount last night with milling the block to size
Tonight I hogged out the cylinder recess
Making lots of Christmas decoration in the process
Then I contoured the end
And finally drilled the mounting holes
I am quite please with how it turned out so far
Bruce
Offline Ian S C
« Reply #22 on: December 12, 2016, 02:39:03 PM »
Hi Bruce, like the idea of turning the piston from square.
Was up in Wellington last week, came home to Canterbury on Thursday, and hoped to get a view of the coast on the way south (Jet Star), cloud all the way.  A week or so and the road Chch to Kaikoura should be open to one lane traffic.
Ian S C
« Reply #23 on: December 13, 2016, 12:07:05 AM »
Looking good Bruce. Any progress is good progress.---Brian
Offline bruedney
« Reply #24 on: December 22, 2016, 06:00:14 AM »
Hi everyone
I have made a bit more progress but no machining shots I'm afraid.
Family shot
Head close up (man those valve cages and valves a small)
The slightly modified Push rod guide
Bruce
« Reply #25 on: December 22, 2016, 12:36:08 PM »
Looks very good to me Bruce. You'rs will be the first engine up and running in 2017.---Brian
Offline eweb101
« Reply #26 on: December 23, 2016, 04:03:54 PM »
Hi Bruce, can you post a link for which engine this is?
I did a quick search and found lots of Brian's engines but can't figure out which one this is.
Offline bruedney
« Reply #27 on: December 23, 2016, 09:05:11 PM »
http://www.modelenginemaker.com/index.php/topic,6248.0.html
Merry Christmas everyone
Bruce
Offline eweb101
« Reply #28 on: December 23, 2016, 07:08:33 PM »
Thanks! That'll make it easier to follow along:)
Offline bruedney
« Reply #29 on: December 28, 2016, 06:28:46 AM »
Had a ball in the workshop for over the last week but only a small bit of progress on the engine
Got the Rocker arm and pivot sorted
I got a pair of dial gauges for Christmas and the plan was to make a tramming tool for the mill.
And then I thought "Where am I going to store it?"
Trimmed up a chunk of cedar and turned it into this
Bruce
« Last Edit: January 04, 2017, 11:20:54 PM by bruedney »
Offline Steamer5
  • The "Naki" New Zealand
« Reply #30 on: December 28, 2016, 07:17:52 AM »
Hi Bruce,
 Taking orders?
Very nice sure it'll serve you well!
Looks like you had a fun Xmas!
Cheers Kerrin
Offline bruedney
« Reply #31 on: December 28, 2016, 09:32:07 AM »
Thanks Kerrin
I could make you one but it wasn't really that hard
I read through this build thread and then just went from there
http://madmodder.net/index.php?topic=1077.0
The dial gauges were from TM (http://www.trademe.co.nz/business-farming-industry/industrial/manufacturing-metalwork/lathes-accessories/auction-1229927681.htm)
Bruce
« Last Edit: December 28, 2016, 09:01:07 PM by bruedney »
Offline Steamer5
« Reply #32 on: December 28, 2016, 11:04:01 AM »
Hi Bruce,
 Thanks for the links, you did a nice job of Stu's version of Bogs design. The link to the dial supplier has lots of other goodies!
Cheers Kerrin
Offline bruedney
« Reply #33 on: December 31, 2016, 06:35:19 AM »
I have been working on the JAG Carb
What a fiddly little beast it is
First attempt was binned due to square stock not being centred correctly on lathe
Second attempt has almost been binned due to metric conversion errors but hopefully all will be well (should have moved the Air bleed screw away from the centre bore a bit more)
Here is a pic of yesterday and today's efforts
Just the Spray bar assembly to go but I am away down south for a week so this is it for this year.
Hope everyone has a great New Year celebration.
May there be much swarf and model making for you each in the New Year.
Stay safe everyone
Bruce
« Last Edit: November 29, 2019, 06:45:21 AM by bruedney »
Offline roboguy
« Reply #34 on: December 31, 2016, 08:59:17 AM »
Fantastic work as always Bruce. Can't wait to see it running!
Offline bruedney
« Reply #35 on: November 29, 2019, 06:37:55 AM »
Well it's been a while but good things come to those who wait. It lives
<a href="https://www.youtube.com/watch?v=M6_mx-8kjGU" target="_blank">http://www.youtube.com/watch?v=M6_mx-8kjGU</a>
Running on meths with  RCexl ignition system
Bruce
Offline doubletop
  • Wellington NZ
« Reply #36 on: November 29, 2019, 08:46:48 AM »
Bruce
Strange but I couldn't see the Youtube link until I quoted you
[youtube1]https://www.youtube.com/watch?v=M6_mx-8kjGU[/youtube1]
(I think you need to use the second set of YouTube tags, 4th from the right. youtube1 )
Now I'll take a look
« Last Edit: November 29, 2019, 08:50:15 AM by doubletop »
Offline doubletop
  • Wellington NZ
« Reply #37 on: November 29, 2019, 08:49:07 AM »
Bruce
Looking great!!
I see you are also using Ryobi electric start.
Offline ShopShoe
  • Central Iowa, Central USA
« Reply #38 on: November 29, 2019, 01:02:31 PM »
Congrtatulations on a runner.
"The Wait" seems to be what a lot of us have....
ShopShoe
