I am taking a short sabbatical from building my traction engines to have a go at designing and machining some of the more intriguing types of gears, and looking at the mathematics behind them. I've been rabbitting on about helical gears, and the mathematics behind them for some while, so I thought it was about time I actually machined some.
I started with a couple of helical gears intended to run on parallel shafts, which means that one needs to be right hand and one left hand. I like sensible size gears; 6DP and 24 teeth seemed like a good place to start, and a 30° helix angle, as that is within the capabilities of my universal mill but large enough to be interesting. Although the gears are imperial my mill is metric so I had to translate the lead into metric to see if it was close to one listed in the dividing head manual. Setting up the mill by swivelling the table and adding the dividing head and gear train from table to dividing head proved fairly straightforward. I ran the HSS steel cutter at 117rpm. The initial feedrate based on 4 thou per tooth was a bit ambitous, not least because the cutter was somewhat eccentric and was only cutting on two or three teeth. I ended up with a feedrate equivalent to about 1.6 thou per tooth. Here is the basic setup:
The gear train can just be seen on the extreme left. And before any smartypants points it out I know the dividing head is the 'wrong' way round. But that's how it worked out with the kit I've got and the way the gear pickoff is orientated on the mill table feedscrew. The gear was cut in one pass; material is low carbon steel, EN1A in English money. I had a few fumbles with the first attempt, I was relying on the grip of the dividing head chuck to resist the cutting forces; it didn't.
Hence the rusty spacer that can be seen to the left of the gear blank. Another important point is that it helps to tighten up the milling cutter arbor before machining.
Shown here is a close up of the cutting process:
The machine has flood coolant, so I used it. It's been a while since I used the horizontal mill and the coolant was mostly water, which meant that the EN1A rusted as you looked at it. I had to add a few yoghurt tubs of coolant before the refractometer registered a sensible concentration of about 7%. This is the finished gear, the OD is a tad under 5" and the face width is 1":
For cutting the left hand gear it is, in theory, a simple case of swinging the table the other way and adding an idler gear to the gear train to reverse the rotation direction of the dividing head. However, as seen here it isn't that simple:
To get access to the dividing head I had to move it across one T-slot, and add the home made risers so that the dividing plate cleared the table. I also had to move the milling cutter to it's outermost position. When I bought the dividing head I got a lot of the accessories, including the full set of gears, but I was missing one keyed sleeve and some internally threaded collars to hold the gears. Once the thread (non-standard at 7/8" 16 tpi Whitworth) was established it was pretty quick to knock out the required parts. The two black knobs at the bottom of the picture are for the table feed gearbox. There are 18 feeds in total, nine due to combinations of the handles and the feed motor is two speed. If I recall the feed motor is 1hp induction. That's a bit odd because all the feedrates are in the ratio 3:2 between high and low ranges. All I can think of is that the induction motor is pole switching between 6 and 4. Finally here are the two finished gears:
They seem to mesh well and the action feels very smooth. Centre to centre distance agrees with the maths too, at least as measured with a rule.
So having done the low helix stuff, how about a high helix helical gear? Clearly I can't do this with the same set up, as the table only sviwels ±45°. I also don't have the universal vertical head for my horizontal mill that is needed for low lead (aka high helix angle) milling. However, I reckoned I could achieve the same thing on the Bridgeport with a right angle head. That needed more adaptors to be made so that the gear train could be connected to the table leadscrew. In deference to the less rigid set up I chose to use 14DP with a helix angle of 70°. I chose 17 teeth giving an OD of about 3.7". That allowed me to make the gear blank from the middle of the foul up that was maquerading as the first attempt at making a helical gear. Here's the basic setup, for convenience in the gear train there is an idler, so the resulting helical gear will be left hand:
And a close up of the gear cutting in action:
Note the felt tip pen numbers; I always check the indexing before cutting. Been there, done that, and set the dividing head up incorrectly. For low leads it is recommended to turn the dividing head plate, rather than the leadscrew. That way the dividing head is driving the leadscrew through a reducing gear train. I didn't have much choice, as the feed motor on the Bridgeport didn't step up to the plate. it just sat there stalled. To get proper leverage on the dividing head plate and handle I used a bit of plastic tube. If I was doing this for real, rather than just as a fun exercise, I'd make a handle that fitted properly. Here is the resultant high helix gear, I'm quite pleased with it:
I had intended to leave the helical gears there and move on to other things. But I've decided to make a mating gear for the high helix gear for shafts at right angles. So the horizontal mill is now set up to cut a 14DP, 36 tooth, 20° helix, left hand gear.
Overall this exercise has gone quite well and I feel that I can now make helical gears if required, and more importantly to me I also have a basic understanding of the mathematics behind them. If I get really bored in the future I'll have a go at making a helical gear on the CNC mill. Milling helical features is not a problem, so it's just a matter of ploughing through the trigonometry to work out the toolpath for a normal endmill to form the tooth (space) shape in multiple paths.
For the purposes of this exercise I bought some cheap import involute cutters from a UK ME supplier. They're crapsky, although I can't say I'm surprised. They all have eccentricities, and both the 14DP cutters have a noticable wobble as well as eccentricity. I haven't measured it, but it is very obvious visually, so probably 10 thou or so.
For the purposes of making these gears it didn't really matter, but I sure wouldn't use them to make gears for a proper project.
It is also entirely proper to make an acknowledgement. Although I sketched out the basics of the gears by hand I made extensive use of the Excel spreadsheet by 'Don1966' to quickly do trial and error calculations to get convenient lead values. I just added a couple of cells to convert the lead from imperial to metric. Thanks Don!
Now onto internal gears. I've sorted out the mathematics of the internal gear tooth shapes and have designed an internal gear and pinion in 3D CAD. I 3D printed these last weekend and all seems to work as expected. I have a quick play with them every time I pass the dining room table.
I also have a measure of the interference problems that can afflict internal gears, and the mathematics behind it, but that needs a bit more work. I'm now designing from scratch an internal gear and pinion, but with a 20°PA. Once done I'll 3D print them again and then make them in steel, just to prove I can do it.
Andrew
