Author Topic: AOG's version of the Liney 5  (Read 5474 times)
Offline gerritv
  • St Catharines, ON
Re: AOG's version of the Liney 5
« Reply #15 on: November 14, 2016, 10:27:58 PM »
Beautiful work at a rapid rate.
Thank you for the illustrative photos, lots to learn about work holding etc.
« Reply #16 on: November 15, 2016, 01:00:23 AM »
More great progress Tony and yes, you are moving right along too!!
« Reply #17 on: November 17, 2016, 03:53:35 PM »
Yep I would have to agree with the rest. Definitely moving at a rapid rate but good looking parts though.
Very nice Tony....... :ThumbsUp:
« Reply #18 on: November 17, 2016, 04:38:08 PM »
Your parts are looking great Tony!  It's fun seeing this project develop.
Offline AOG
« Reply #19 on: November 17, 2016, 10:08:18 PM »
Ok last couple of parts. The first one is the pulley. I started by profiling it.
Then the center was drilled for the retaining screw and parted off.
Next up is the flywheel. I dinked around with Tinglet's flywheel tool until I came up with something I liked.
The flywheel I came up with is actually wider than the grip area of the crank shaft so I decided on having a center hub on only one side.
I marked out and trepanned the side without the hub first.
Then the part was flipped and the hub side completed.
The the flywheel was mounted on the rotary table and corner holes drilled. I should have added some additional clamps because I got some rotation of the part although it wasn't apparent at the time.
I did add additional clamps before milling out the edges of the spokes.  Unfortunately it was too late. If you look you can see that the angles are slightly off on the intercept. In the end it wasn't a big deal but it did make for significantly more clean up at the end
The outer curve was then cut and the part trued up on the lathe.
That completes the machining on this project. Now it's all about fitting and finishing. I'll end this log with a final family shot.
Next time you see it will be in the showcase.
Till next time
Tony
« Reply #20 on: November 17, 2016, 11:33:50 PM »
Very nice Tony, Looking forward to seeing it run. I like the flywheel BTW  :ThumbsUp:
Offline AOG
« Reply #21 on: November 27, 2016, 09:18:17 PM »
I had a few bumps in the road but she's a runner. Final pics can be found here.
http://www.modelenginemaker.com/index.php/topic,6621.0.html
Thanks
Tony
