Hi Chris, The cylinders are coming on, very nice work.......mind you we have come to expect no less.......the gnomes have been quite for a while, have they got something else they are playing with?One question though, how come you didn't recess the nut in the top of the piston? Helps keep the swept volume down & allows the piston stroke to be more even.......well that's what I got told anyway.Cheers Kerrin
Great work on the Cylinders Chris.You're planning to run this on actual steam, right? Will the paper gaskets cut it? Or do you need something more substantial to hold up under the temperature and moisture of steam? I'm wondering this form my own build...Thanks,Kim
OK, that makes sense. I'm going to have to find me some of that fiber gasket paper!Thanks Chris,Kim
