Author Topic: Chris' Build of a Lombard Hauler Engine  (Read 445933 times)
« Reply #630 on: January 29, 2017, 10:03:41 PM »
And a quick double-check that all the sizes are good, and an inspiration to myself to get them done, assembled the first length of the drive chain...
« Last Edit: June 04, 2018, 01:22:33 AM by crueby »
« Reply #631 on: January 30, 2017, 12:41:16 AM »
Still following along Chris. Things are looking great!!  :popcorn:
« Reply #632 on: January 30, 2017, 12:53:42 AM »
Because of Chris? Or his elves? One begins to wonder who's doing the work.  :thinking:
Mint chocolate chip cookies are a powerful bribe.
« Reply #633 on: January 30, 2017, 01:03:28 AM »
They sure are! NASA put a trail of them into the capsule to get the astronauts in...
« Reply #634 on: January 30, 2017, 01:05:40 AM »
Thanks Bill! Once the repetative work on the chains is done, I can start on the sprockets and gears, good thing no repetitive work there... Hey... Wait...
« Reply #635 on: January 30, 2017, 01:09:51 AM »
Yeah. You keep saying 'I' but you mean 'they'.  ;D
« Reply #636 on: January 30, 2017, 01:39:29 AM »
'They' have taken me over, we are us now!
And 'We' just made 'me' get out another handful of mint chocolate chip cookies.... yum!
« Last Edit: January 30, 2017, 01:43:01 AM by crueby »
« Reply #637 on: January 30, 2017, 04:21:43 PM »
Progressing forward on the drive chains, got the first half of one done...
« Last Edit: June 04, 2018, 01:22:49 AM by crueby »
« Reply #638 on: January 30, 2017, 05:01:51 PM »
Hi Chris,
 Think the elves need to go on a diet! Too many cookies & progress slows!
Keep them lean & mean!  :Lol:
Looking Good!
« Reply #639 on: January 30, 2017, 06:40:21 PM »
Hi Chris,
Looking Good!
Sure. YOU deal with a hungry pack of annoyed shop elves! That is how they turn back in to shop gnomes and start hiding your tools!
« Reply #640 on: January 30, 2017, 06:41:55 PM »
And one drive chain done! I did not rivet in the final pin, in case I need to add a link or two once the sprockets are in place. It should be the right number now, but thats when Murphy comes a callin'...
One more drive chain to go...
« Last Edit: June 04, 2018, 01:22:59 AM by crueby »
Offline GailinNM
  • Albuquerque, NM, USA
« Reply #641 on: January 30, 2017, 07:58:19 PM »
Beautiful Chris.  If I tried to do that it would be Groundhog day 2018 before I got one done.
Gail in NM
« Reply #642 on: January 31, 2017, 07:04:24 AM »
[/quote]
[/quote]
Hahahahhahahahahahahahahha!
Chain looks good!
« Reply #643 on: February 01, 2017, 04:16:05 PM »
And both chains are done!   :whoohoo:
I took them up to the belt sander to ease the sharp corners on the links, looks a little better, and also cured a couple of sticky spots.
Now back to the lathe, started turning down the blank for the small end drive sprockets...
« Last Edit: June 04, 2018, 01:23:07 AM by crueby »
« Reply #644 on: February 01, 2017, 10:14:24 PM »
After shaping the hub side of the smaller sprockets and parting them off, turned them around in the chuck to face them to thickness and taper the second side to match the first, so that the chains will self center.
and then over to the rotary table on the mill to plunge cut the bottom arc of each tooth,
and then offset the table 20 degrees and .475" to cut the shoulders on one side,
and then the same angle/distance the other side of zero to cut the other side of the shoulders
leaving the finished sprockets (just needed a little filing to remove the burs on some of the edges).
Next up are the back sprockets, which are 20 teeth each. For those, I think I am going to start with some flat bar for the sprocket disc, and silver solder on a hub, rather than starting with a big chunk of 2-1/4" bar stock and turn most of it away. Either way will work, this way gets me more silver soldering practice.
« Last Edit: June 04, 2018, 01:23:12 AM by crueby »
