That curved T might need to be printed. Perhaps a Shapeways job?I presume the door hinge was checked against interference with the blast nozzle.
They print the part in wax and cast it in the material you choose. Cost is per cubic cm, so you can design and upload an STL for free to get a quote.Two 90-degree el fittings machine in the center of the output and soldered might work as well.
Chris,They use a 3D printer to print the part and it can be hollow, you have to obey the thickness rules for the material. The wax is then investment cast which also works with hollow parts as the investment will fill the void. The bronze is 90% copper 10% tin so that is my usual choice. I have had casting numbers put on 7/8" Shay truck boxes and it looks great.Dan
Hi Chris.I have been following along since day one of the build. I have picked up so many tips and machining setups along the way. A very unique and outstanding build.gbritnell
As an exercise in Solidworks, I modeled the T. I uploaded it to Shapeways, and the cost to cast it in either bronze or brass is $14. As modeled, I set the wall thickness to .015", which they gave a warning about. Should be about .025" minimum. The tubes are .25" diameter so that could be adjusted to fit the scale.I also submitted a half section thinking that two could be soldered together, but the price each was the same.It would probably not cost much to add the three flanges and save that part of the job.Not sure how it would be done in Inventor, but in SW it's 2 sweeps and 2 sweep cuts.
