Author Topic: Metric Transposition gears  (Read 14824 times)
Re: Metric Transposition gears
« Reply #30 on: September 09, 2012, 02:57:12 AM »
Dave I really appreciate this, it should help a lot. I owe you one bud.
Many thanks Don
« Reply #31 on: September 09, 2012, 03:06:54 AM »
Dave I ran into a problem with you XL spread sheet. I have office 2003 and it doe not support XLXS format. Resave it in XLS format and repost. Select save as and change file type and resave.
Thanks Don
Online steamer
« Reply #32 on: September 09, 2012, 03:13:35 AM »
Will do Don!
Online steamer
« Reply #33 on: September 09, 2012, 03:18:11 AM »
Here ya go Don
The attached is the 97-2003 version
« Last Edit: September 09, 2012, 03:34:31 AM by steamer »
Offline Maryak
« Reply #34 on: September 09, 2012, 03:21:09 AM »
Don,
I have the same problem below is a link to a free converter from Microsoft.
http://www.microsoft.com/en-us/download/details.aspx?id=3
Hope this helps.
Best Regards
« Reply #35 on: September 09, 2012, 04:01:35 AM »
Thanks Dave, and thanks Bob. I will run some test on it just to make sure all of the formulas tags are working. I don't know how much different the formulas tags are with the newer software, but I hope saving it to 2003 takes care of this.
Online steamer
« Reply #36 on: September 09, 2012, 10:51:04 AM »
Shouldn't be any difference at all Don....I checked both versions and they verify just fine.
« Reply #37 on: September 09, 2012, 03:55:22 PM »
Thanks Dave, glad to know that. This will same me some time and mistakes.
Online steamer
« Reply #38 on: September 10, 2012, 01:08:04 AM »
Don,
Make sure you take the backlash out of the rotary table!
« Reply #39 on: September 10, 2012, 02:05:14 AM »
Dave there is a adjustment screw for that, but I haven't had much luck getting it out. I going to have to disassemble it and see how the thing works and maybe get it adjusted right.
Online steamer
« Reply #40 on: October 22, 2012, 10:27:36 AM »
How ya making out Don?
« Reply #41 on: October 22, 2012, 04:48:56 PM »
Hi Dave, I have not finished my gear yet. I did do as you said and finish cutting the bad gear with good results so I am keen on making my gear. Just have to wait till work has slowed down. I will post once I start again.
Thanks Don
