Author Topic: Metric Transposition gears  (Read 18836 times)
Re: Metric Transposition gears
« Reply #15 on: September 08, 2012, 03:01:51 PM »
Don,
What tooth counts are you cutting?
« Reply #16 on: September 08, 2012, 03:17:33 PM »
From what Stuart has told m a 31T and 34T.
« Reply #17 on: September 08, 2012, 08:21:29 PM »
Don,
Have you got index plates for the table?
« Reply #18 on: September 08, 2012, 08:30:50 PM »
Yes I do Dave, I just don't remember which ones I have. I will have to go to my office to check them and will get back to you.
« Reply #19 on: September 08, 2012, 08:32:53 PM »
I need to know the ratio of the Table too.....and we can figuire it out.
« Reply #20 on: September 08, 2012, 08:57:11 PM »
Dave my RT has a 72/1 ratio and the division plate has 28 and 15 hole pattern.
« Reply #21 on: September 08, 2012, 09:25:43 PM »
YUK
I figuire you need a 17 or a 34 hole plate, and a 31 hole plate.....to do a 34 and 31 tooth count gear.
31 teeth
72/31 =2.322581      using a 31 hole plate it would be 2 turns and 10 holes
34 teeth
72/34 = 2.117647    using a 34 hole plate it would be 2 turns and 4 holes
                               Using a 17 hole plate it would be 2 turns and 2 holes.
You could go by the rotary tabel dial if you map out the turns ......I wrote a program to do that once...so Did Marv
Want me to dig it up?
« Reply #22 on: September 08, 2012, 09:49:28 PM »
Any help is appreciated Dave.
Thanks Don
« Reply #23 on: September 08, 2012, 09:54:41 PM »
72/17 = 4 & 4/17
i.e., 4 turns and 4 holes on the 17 hole plate.
« Reply #24 on: September 08, 2012, 10:02:53 PM »
For 17 teeth Marv....not 34...
72/34 = 2.117 turns per tooth
« Reply #25 on: September 08, 2012, 10:08:32 PM »
It's very dumb out today.  Sorry about that.
« Reply #26 on: September 08, 2012, 10:12:34 PM »
No Worries Marv.......
« Reply #27 on: September 08, 2012, 11:40:21 PM »
Thanks Dave, my involute cutter and Keats plate arrived today. I ordered them on the 5th from the UK ,they get here faster then the local orders. My indexer still has not arrived and it's coming from the states.
« Reply #28 on: September 09, 2012, 12:10:55 AM »
OK
Here you go.    I rewrote my spreadsheet for rotary tables.  It is attached below.
Let me explain how it works    Here' a screen dump of the spreadsheet in excel
ONLY alter the numbers in yellow.
In this example, I've inputted a index of 6 positions and a rotary table ration of 72/1.   This would match your table Don.
The spreadsheet shows the degrees, minutes and seconds for each index position, and to the right, shows the absolute position of the rotary table crank to get to each position from the ZERO or start position.
The first index is 12 full revolutions of the crank
The next index is 24 full revolutions of the crank......ect.
Enter the number of index positions required and follow the crank colum until it gets to 72 full turns or 360 degrees    The spreadsheet computes 100 positions automatically...but you know enough to stop when you get all the way around I think.
In this case just stop at 6 positions or 72 crank rotations.
« Last Edit: September 09, 2012, 03:28:42 AM by steamer »
« Reply #29 on: September 09, 2012, 12:14:29 AM »
So Don , in the case of the 31 tooth gear,  enter 31 in the number of index positions box, and 72 in the rotary table gear ratio box
Print out the output and hang it at the mill.    Then one line at a time follow the chart.  Cross out the line you completed with a pen when it's done.
When you get to 72 turns...your done.
