Author Topic: Seeking advice on electroplating  (Read 2368 times)
Offline loggerhogger
« on: October 04, 2016, 04:28:56 PM »
I have a few steam engines I have built over the years including the Cole's Corliss. I have noticed that I am getting the beginnings of rust on areas like the polished flywheel surfaces and other areas I sidnt want to paint. I have been looking at some of the home electroplating kits. I'm thinking of nickle plating these surfaces. Has anyone else done this? How about the effect on the existing paint? Any help is appreciated.
Re: Seeking advice on electroplating
« Reply #1 on: October 04, 2016, 04:50:41 PM »
I use this from Micro Mark.  http://www.micromark.com/Plug-N-Plate-Nickel-Plating-Kit,8326.html It works great and I done an engine and sewing machine with it. It doesn't effect the paint but you need the surfaces well prepare before tinning.
« Reply #2 on: October 04, 2016, 05:01:54 PM »
Thanks Don. Nice job on the sewing machine. Was this a brush on plating kit or a dip tank? Did it have idiot proof instructions?
« Reply #3 on: October 04, 2016, 05:05:35 PM »
It quiet easy logger just follower the instructions. I used plastic trays and emerged the parts in it and you use the wand which is connected to a power supply to pass over the part. The plating is slow but good results. It a cheap kit but did what I wanted...
« Reply #4 on: October 04, 2016, 05:26:32 PM »
Thanks Don
