Hi,
I've now got a little bit further by partly making the eccentric arm, it follows the theme of some of the other parts and is made from 3 steel rings that will attach to the eccentric sheath.
After turning them to size they need drilling to take a brass rod for soldering together.
Apart from a few practice run on pieces of scrap this is the first time I've soldered so I'm not sure what to expect.
It's never going to get me into the Guild of Master solderers but I'm quite pleased with it as a first attempt.
The rod that will attach to the rings at the valve end is a simple threaded affair with a taper at one end to blend with the smallest ring.
My tailstock chuck is a perfect match with the diestock to help getting accurate threading
With the top slide at a 10
o angle I can cut the taper.
I need to have a bit of a think before decide how to machine the other end of the taper to match the rigs so I'll call it a day for now.
The handle looks to be leaning but its just that there is still a small pip on the bottom after parting off - the rings are smooth on the inside despite how the look and just a bit more emery should clean them up.
I'm hoping to get some wood for a base tomorrow so with a bit of luck I ought to be ready to start testing it shortly
Peter.
