No electric motors on Monitor but the big hand wheel does drive a screw that shifts the eccentrics.
There has been some discussion of the correct angle with a good contribution by Tim (Tvought) as what is needed to achieve a symetric forward/reverse valve position as a function of "the angle of advance" which depends on the length of the connecting rod and the crank throw. It is never exactly 180 deg just as adjusting the eccentric/crank lead is never actually 90 degrees, but it is a good starting point.
After making my post last night, I went back to the videos of Ericsson's gear and see that I was slightly mistaken. The gear only rotates the two outer eccentrics which control the slide valves and not the two inner eccentrics which control the cut off valves. This would seem to put the cut off valves out of sync with the main valves. There is a very convenient lever that by-passes the cut off valves and seems likely that cut off would not be needed in reverse. You have to remember that the valve rods work through crank/levers where the outer eccentric rod motion is translated to the inner valve rod motion.
If you haven't seen this, here is a YouTube link to Carlstadt's model.
[youtube1]https://www.youtube.com/watch?v=VWn8gQ9Ykpk[/youtube1]
