Author Topic: help with identification and sizing  (Read 7515 times)
Offline ziggar
« on: September 02, 2012, 01:29:39 PM »
 Afternoon Gents and Ladies
Yesterday I went to a booty and happened upon these items and thought they would be of some use in the workshop somehow.
They have a normal tapping thread at one end and the other end is simply bent over at 90˚.
Anybody know what they're called and does anyone know how to identify the various sizes ?
If i try to rub the rust off the shaft then any sizing marks underneath are going to be rubbed away too.
Any help greatly appreciated
Thanks
Z
« Last Edit: September 02, 2012, 01:47:18 PM by ziggar »
Re: help with identification and sizing
« Reply #1 on: September 02, 2012, 01:57:01 PM »
Nut tapping machine taps, see my reply on ME and this thread
http://www.model-engineer.co.uk/forums/postings.asp?th=64811
Offline ziggar
« Reply #2 on: September 02, 2012, 02:38:35 PM »
do you follow everyone around various forums and answer their questions with the same reply ?
why couldnt you leave it alone and let someone else have a go and maybe come up with an answer to the other part of my question or is that not allowed ?
« Reply #3 on: September 02, 2012, 02:53:22 PM »
Ok measure the pitch of the thread either by using a thread pitch gauge, rule or offering up screws of a known size. Measure the dia as best you can, not always easy on a 3 flute tap. Then sit down with your thread charts and work out what the likely candidates are, same method you would use if trying to find out what thread a screw is.
PS why waste peoples time all posting replies to the same question on at least 3 different forums just saving people wasting their time. Better to ask on one forum and wait a while then if no replies ask elsewhere. Oh and a thankyou for aswering the question would not go amiss.
« Last Edit: September 02, 2012, 02:56:52 PM by Jasonb »
Offline arnoldb
  • Windhoek, Namibia
« Reply #4 on: September 02, 2012, 03:03:15 PM »
Thank you for explaining Jason; I was curious about these devices myself.
Kind regards, Arnold
Offline ziggar
« Reply #5 on: September 02, 2012, 03:20:22 PM »
Thank You for your second reply
NOT the first
the reason i asked on various forums is because not all people visit all forums and someone else might have had a different answer had you not chipped in pointing all to the one reply, which in itself came across as telling me not to ask questions.....
« Reply #6 on: September 02, 2012, 03:40:33 PM »
Hey guys....lets leave this lay alright?   Points made and taken...lets all just move on.
Offline 90LX_Notch
    • YouTube Channel
« Reply #7 on: September 02, 2012, 04:34:27 PM »
Use a Dremel with their small wire wheel to remove the rust without hurting any size markings.  Unless of course, they are printed or etched.
-Bob
Proud Member of MEM
My Engine Videos on YouTube-
Offline ziggar
« Reply #8 on: September 02, 2012, 05:22:46 PM »
-Bob
that's the problem there Bob, should have mentioned that
the ones that Ive tried to clean seem to have etched or printed markings and after cleaning I only manage to see the remnants that then make no sense.
I tried using a piece of scotchbrite with some wd40 as a lube rubbing as gentle as I could but still managed to remove the markings. I don't know of a way to remove the rust without removing the markings. Now if someone were to come up with a magical way of removing one without removing the other, that would be great  ;D
« Reply #9 on: September 02, 2012, 05:28:52 PM »
You may need to experiment with some of the popular rust removeal compounds.    I'd try CLR for one.   Simple Green will take some surface rust off.
Offline ziggar
« Reply #10 on: September 02, 2012, 06:25:41 PM »
being in the UK I'm not familiar with these mystical items that you talk of :)
anything stronger than Fairy washing up liquid seems to be on some 'forbidden' list somewhere and impossible to obtain
even basic rust eater type solutions are going "organic" and making them basically useless
i have some hammerite rust eater type jelly type stuff here
will have to give that a go tomorrow
but even that's all elf and safeteed up now
Offline Deko
  • Crewe, Cheshire, UK
« Reply #11 on: September 02, 2012, 07:39:33 PM »
Like Jason said they are used on a machine for tapping nuts. I have loads of them from Andrew Johnson over on the ME site,and they are very usefull when tapping lots of through holes in material no thicker than a nut of the same size,as you can go strait through without having to wind them back out.
Cheers Dek. :old:
« Reply #12 on: September 02, 2012, 07:45:07 PM »
Putting your location beneath your avatar will help people to better focus their suggestions in the future.
Offline swilliams
  • Canberra Australia
« Reply #13 on: September 03, 2012, 12:50:17 AM »
Alot of rust removal concoctions are based on phosphoric acid. Apparently molasses is very effective, but I've never tried it.
see - http://en.wikipedia.org/wiki/Phosphoric_acid#Rust_removal
« Reply #14 on: September 03, 2012, 12:58:22 AM »
There is always Cokacola......
