Got the cast iron cylinder profiled and today, I bored it out. I was sneaking up on the bore dia. of .873 and measuring on the lathe it was .872. Took it off the lathe and it measured .904! I have no idea what happened there! Good thing is, it measured the same on both ends of the bore.2 more questions, what do/can I use to hone the bore, and will the 7/8 Viton 0-ring still work. I see our(US) Horrible Freight now carries an assortment of Viton O-rings. Finish on the cylinder isn't my best, but I'm happy with it. Seems the barbell cast iron is quite porous, has tiny pits on all surfaces. Pictures to come, camera batteries are flat, as seems is always the case when I want to take pictures.Chuck
