My bed is heated to 160C for PLA
Hi GordonGoogle is your friend, so I googled : micro sd card compatibility issuesBest wishesPer
In regard to a glass bed, do you just place a piece of glass on top of the metal bed?
The glue sticks release the part very easily once the bed cools. When warm, they are hard to remove.
QuoteMy bed is heated to 160C for PLA Typo ?? sounds Way high 60-70c typical also common to have first layer nozzle and bed about 5 degrees higher than rest of print. Tin
When you set the height of the head over the bed, I assume that it must be set with the tape in place and not over the bed without the tape since the tape itself is about .003 and if it were set to the bed the head would actually touch the tape. True?
