Thank you both Yes I can definitely appreciate the advice given to me when I made my intro post on this forum: "start small".I am starting as small as possible and I'm still making errors
Hello again,I finally purchased myself a bench grinder, a Linishall BG8 model.I also had my first "D'oh" moment on the lathe.I was working on Metal Scriber Mk II using a piece of previously turned down 3/8th inch brass rod. All was going well; I just finished cutting the taper, but instead of backing out the cutter, I accidently turned the wrong way and plunged it in, carving out a wide ring in the scriber. I was demonstrating an old Drumond lathe to a friend recently and the top slide had a right handed thread installed!!. So every time i tried to take a cut it moved in the wrong direction !!! i think it was maybe a left handed persons lathe or something else..........I attempted to correct it by re-cutting the taper until the ring disappeared; unfortunately the length of the scriber was now too short, and the taper too long. Oh well, on the plus side it only took me 25 minutes this time to turn down the next bit of 1/2 inch brass rod stock down to 3/8th, so at least I am getting faster at starting from scratch
Congratulations - it looks great and you should be very happy with it Chris at the site you linked to showed it nicely - if you have a mill - if not .... I cheat. When I did my Viking 2.5cc diesel, I used the lathe to mark the centre diameter of the holes. Next I used a digital angle meter on the chuck, set it to zero, turn the knob for the cutting depth to make a small line across the diameter mark. Backed the tool a bit and rotated the chuck until the angle meter shoved 60 degrees, turned the knobs again to make the next small mark. If you repeat this another five times, you end up with a circle divided by 6. Another way of doing this with the divider, as the radius of a circle divides it into 6 or 60 degrees apart.
