Pediment
You clearly had an im-pediment to your memory
I'm not so sure about that if the language hasn't been butchered up. < Pediment > The Ped part means foot so I'd suspect that is for the "thingy" at the bottom of the column. ...lew...
I wish you lot hadn't started this. I suddenly felt the need to go and visit my favourite building in the whole world only to find that my last passport ran out three days ago .Jo
Quote from: Lew Hartswick on July 16, 2016, 03:51:23 AMI'm not so sure about that if the language hasn't been butchered up. < Pediment > The Ped part means foot so I'd suspect that is for the "thingy" at the bottom of the column. ...lew...And you would be wrong. See...http://www.dictionary.com/browse/pediment?s=tYour (gag) "thingy" is properly called a 'plinth'.
As well as the entire region in Virginia east of the mountains " Pedmont" . :-) So just another misuse of a Latin prefix that has been in use for quite a while, I guess.
A sketch or drawing might be helpful, but if you mean the triangular end of a columned building, or the triangular end of an attic, it would be a Pediment or Gable. Plinth is incorrect, as that is a flat slab base under a column, pedestal, or statuary.
II suddenly felt the need to go and visit my favourite building in the whole world
So Jo does this building have stone colunms or Cast Iron Columns?
