Author Topic: Finally!  (Read 4262 times)
Arbalest
Finally!
« on: September 01, 2012, 06:34:54 PM »
Managed to finish this Knurling tool I started making a long time ago  ::)  ;D:
Should knurl from around 5mm up to about 50mm but not tried it fully yet!
Re: Finally!
« Reply #1 on: September 01, 2012, 06:44:06 PM »
Nice! What have you used to blacken it?
Arbalest
Re: Finally!
« Reply #2 on: September 01, 2012, 06:55:48 PM »
Nothing! Must be just the pic, it's been sandblasted then finished with Renwax to stop it rusting.
Re: Finally!
« Reply #3 on: September 01, 2012, 07:01:42 PM »
That would explain it ;).
I have a chemical blackening kit and too often the finish is too dark. Getting an even finish with bluing is a bit hit and miss. The wax and a camera could make it look that lovely shade.
Offline tel
  • Bathurst District, NSW, Oz.
Re: Finally!
« Reply #4 on: September 01, 2012, 09:36:02 PM »
You've done a lovely job of it - makes my effort look pretty crude.
Arbalest
Re: Finally!
« Reply #5 on: September 01, 2012, 10:28:43 PM »
Thanks. It's not exactly as planned as I had to work around the fasteners I had to hand but there's no slop in it like the import ones!  :ROFL:
Re: Finally!
« Reply #6 on: September 01, 2012, 10:29:30 PM »
Looks Great!
Re: Finally!
« Reply #7 on: September 01, 2012, 11:39:19 PM »
That is a nice looking knurling tool. Great job.
Offline petertha
Re: Finally!
« Reply #8 on: September 19, 2012, 04:12:47 AM »
Nice. Can you elaborate on the axle bolts the knurling wheels ride on? Are they socket shoulder bolts like these or hollow axles with a bolt? Seems a lot smarter than this Eagle Rock knurler I have. Itknurls fine enough but I find removing the wheels a painful excercise... which is why 95% of my knurls are teh same pattern! The dowel pin type axles are pressed in very tight, so I end upusing makeshift press tools cranked in vice jaws.
Arbalest
Re: Finally!
« Reply #9 on: September 19, 2012, 10:40:57 AM »
I used shoulder screws as in your first picture Peter. Only takes a minute to swap Knurls.  :naughty:
