Author Topic: 3 cylinder radial aero engine whats it worth??  (Read 4994 times)
Offline lozpeters
« on: July 09, 2016, 03:21:14 PM »
Hi all,
a few weeks ago i saw a 3 cylinder radial engine on an old RC plane in my local junk/house clearance shop. I saw it is still there today does anyone have any idea on what this might be worth??
 i recon it will need a bit of restoration to get it working but it looks in OK condition and must of been in the shop for a fair amount of time considering the dust on the plane! when i asked a few weeks ago i think he said the plane was £300 would this be a good deal?
cheers
loz
Offline petertha
Re: 3 cylinder radial aero engine whats it worth??
« Reply #1 on: July 09, 2016, 06:52:16 PM »
I really depends on what you are looking at - condition, displacement, vintage etc. Commercially, I know Saito made/makes 3-cyls, not sure of many other manufacturers, but possibly in the past? And there are also plans out there if maybe it was a model engineer build.
http://www.horizonhobby.com/product/airplanes/airplane-accessories/airplane-engines-15042--1/33cc-3-cylinder-gas-radial-engine:-bs-saieg33r3
http://www.cad-jung-shop.de/Construction-plans-for-3-cylinder-radial-engine
http://www.homemodelenginemachinist.com/showthread.php?t=2270
« Reply #2 on: July 10, 2016, 12:06:51 AM »
Hi Loz,
 There is a company here in New Zealand that will build you a full size radial WW1 replica if you want one! The guy has figured out how to put electric start on it too. Mind you it will cost you a bit more than 300 quid!
As to what the one you are looking at.... Well no real idea but you do get a aircraft to go with it. Sounds like you might have to go have another look & see if you can get a close up & some idea of what the engine might be, it could be one of those that Jo has piling up in here lounge....eerrrr cast storage area.
« Reply #3 on: July 10, 2016, 05:14:12 AM »
My castings live in the Library (with Sexy and the Cowells) unless they are taken out for a fondle or to sit on the Dining table prior to the final transition into the workshop  :embarassed:
It would be a rather big model if it had one of our Anzani engines fitted to it
