A little doodling.....with my computer.....It scales pretty close!....1" bore x 0.812 stroke40 tooth 32 DP crank and power take off gears.Crank is about 10" long.....
Sure would make a pretty cam though. Bill
Dave,Have you seen the "How It's Made" tv show on Discovery where they make a Jaguar crank by cutting the blank from a solid bar with a large diameter toothed cutter in the lathe. The Camshaft is done similarly. One rotation of the blank and a nearly finished crank emerges.could it be done in the home shop?Mosey
