Thanks Cletus, hope you had an enjoyable 4th of July. Wish you would stop sending the heat this way though Bill
Cletus, after the P&W, it's back to the 1903 Wright engine, though I will be doing some work on the little brother casting set too. The Weight engine is a long term project.
Quote from: b.lindsey on July 06, 2016, 01:33:52 AMCletus, after the P&W, it's back to the 1903 Wright engine, though I will be doing some work on the little brother casting set too. The Weight engine is a long term project. re: the heat and humidity. Does anyone live in perfect weather?Would you want to?
Quote from: zeeprogrammer on July 07, 2016, 01:16:06 AMQuote from: b.lindsey on July 06, 2016, 01:33:52 AMCletus, after the P&W, it's back to the 1903 Wright engine, though I will be doing some work on the little brother casting set too. The Weight engine is a long term project. re: the heat and humidity. Does anyone live in perfect weather?Would you want to?I don't know sometimes Southwestern Idaho has perfect weather and it is pretty darn nice; right now it is 78 degrees and 21%. Pretty nice weather for July! Just don't ask me about it in January. Dave
I sure hope not; we're lucky to get 3 to 4 inches at a time in the city usually less; I think I shoveled once or twice last winter and it was only a skiff. Single digit temps are not uncommon though.
