The gear cutting went very well. I have a set of dummy shafts set up at the correct center distance in a scrap of aluminum plate, and all the gears I cut are checked for correct mesh before I tear down my rotary table set-up. The second picture shows both gears finished, and the hub ring attached to the smaller gear. I'm probably going to go ahead and finish the valve cam and install it on the large gear before I install the gears in the engine. I still don't have my oilite bushings anyways, so I may as well get the cam finished now.
