Author Topic: LMS Oscillator  (Read 6649 times)
Offline chucketn
  • East TN, USA
LMS Oscillator
« on: August 31, 2012, 11:58:19 PM »
Well, it's a runner! I built the LMS Oscillating Engine.
http://littlemachineshop.com/Products/Drawings/2593OscillatingEngineAssembly.pdf
Not really complex, but it ran the first time I put air to it! Not pretty yet, but I plan to bling it up a bit.( This is the engine I asked about making a double acting, got ideas for that, too!) Spent the afternoon running it in and tweaking it. I think I'll decorate the base and upright with "engine turning".
I only have a very loud portable Hausfeld-Campbell portable air compressor, so the requsit video had to wait untill I finished a home brew adaptor to run it off of a computer tech's canned air supply.
Wow! Those cans of air don't last long!
I tried to make a video of the engine using the canned air, but it didn't come out well. I'll try again tomorrow.
Chuck
Edit to add pictures
« Last Edit: September 01, 2012, 12:04:23 AM by chucketn »
Re: LMS Oscillator
« Reply #1 on: September 01, 2012, 12:39:56 AM »
Great job Chuck, there is nothing more satisfying like seeing your first runner. Keep up the good work.
Offline ReFlad
Re: LMS Oscillator
« Reply #2 on: September 01, 2012, 12:49:39 AM »
Nice Job Chuck.  I'll bet you had a lot of fun building it.  Nothing like a runner on the first try!
Ronald
Re: LMS Oscillator
« Reply #3 on: September 01, 2012, 01:32:48 AM »
Nicely done!
Looking forward to seeing the video.
Offline steamboatmodel
Re: LMS Oscillator
« Reply #4 on: September 01, 2012, 02:47:26 AM »
A good start Chuck, If you are using canned air make sure of its contents. Some of the cans used are not air but butane. I found this out while using canned air from a air brush kit to test for leaks in a burner design. I spilled the cup of soapy water I had Ben using and rather than go upstairs to replace it I used a BBQ lighter flame. I almost had to go and change my pants when the "air leak" caught on fire. On looking at he can of propellant I did notice a very small notice that the product was flammable. Why don't you use a long hose on the compressor or let the pressure build up in the tank and then shut the compressor off.
Gerald.
Re: LMS Oscillator
« Reply #5 on: September 01, 2012, 08:50:45 AM »
Well Done Chuck!
Love to see a Vid!.....without blowing yourself up mind you..... ;D.....that would be sub optimal... ::)
Offline chucketn
  • East TN, USA
Re: LMS Oscillator
« Reply #6 on: September 01, 2012, 06:16:37 PM »
As promisced, a video of the LMS Oscillator running, although there is no sound. It's running of the air duster can at the left. It would only run in a few seconds burst before the canned air pressure dropped, but it was self starting!
Now to strip it down and bling it up a bit.
By the way, this is my second running engine, and my third build. I think I'll rebuild my flamelicker that I couldn't get running next. I did a poor job on the cylinder and didn't have any cast iron to remake it.
http://s571.photobucket.com/albums/ss157/chucketn/LMS%20Oscillator/?action=view&current=running.mp4
Chuck
edited to link video after attaching it failed
Re: LMS Oscillator
« Reply #7 on: September 01, 2012, 07:05:17 PM »
Smooth Runner Chuck!   Nice Job!
Thanks for that!
Re: LMS Oscillator
« Reply #8 on: September 01, 2012, 08:02:35 PM »
Congratulations! Looks good!
Thanks for showing the video.
Offline Dean W
    • Home Shop Projects
Re: LMS Oscillator
« Reply #9 on: September 01, 2012, 10:39:35 PM »
Congratulations, Chuck.  It's always a good feeling when a new build comes to life.
Nicely done!
Dean
Dean
In beautiful N. Idaho, U.S.A.
Shop Projects:
Offline chucketn
  • East TN, USA
Re: LMS Oscillator
« Reply #10 on: September 01, 2012, 11:01:10 PM »
I'm working on the bling. Have been sanding the aluminum base and upright on a glass plate from a scanner, with 340 and 220 wet and dry. Some of the corrosion spots and deep scratches wont come out. Do I need to go to more coarse wet and dry? I plan to use "Machine turning with wet and dry glued on the end of a dowel, and then clear or color anodize. The flywheel
I'm happy with except I may paint it between the rim and brass hubs. Any advise?
Thanks for the comments guys...
Chuck
Offline Ross
    • My Steam engine builds and other pieces
Re: LMS Oscillator
« Reply #11 on: September 02, 2012, 12:23:49 AM »
Nice job, I've built that engine too it's fun to build!
Ross
