Author Topic: Made a 1" saw arbor for the mill the last couple of days.  (Read 2959 times)
Online 10KPete
« on: June 15, 2016, 11:18:24 PM »
First pics...hope it works.     Yeaaa, it worked! :cheers:
Re: Made a 1" saw arbor for the mill the last couple of days.
« Reply #1 on: June 16, 2016, 12:04:37 AM »
Nice looking arbor Pete. Is the SHCS long enough to reach to the threaded hole which I assume is threaded into the mount end of the arbor? Could be just the picture but it looks short  :shrug:
Online 10KPete
« Reply #2 on: June 16, 2016, 12:07:06 AM »
Heh, yep the c'bore in the end is quite deep. That's the longest 3/8-24 SHCS I had!! There's about 5/8" engagement
with a 1/8" thick saw.
« Reply #3 on: June 16, 2016, 12:14:49 AM »
More than enough then! Thanks.
« Reply #4 on: June 16, 2016, 12:29:43 AM »
Nice job on the arbor Pete, I like it.......... :ThumbsUp:
Offline jeff l
« Reply #5 on: June 16, 2016, 02:09:29 AM »
very nice job !
Online 10KPete
« Reply #6 on: June 16, 2016, 02:51:59 AM »
Thanks guys, I do appreciate the comments. The Benchmaster, with it's MT2 spindle, is sorta limited for tooling available. The head space is also fairly limited so a lot of off the shelf tooling is less than wonderful, and the 1/2"
max collet size won't handle 3" saws very well. So......
I make a bit of stuff but have never posted anything before.
Offline Chipswitheverything
« Reply #7 on: June 16, 2016, 08:13:26 AM »
That's a very nice design of arbor, Pete, the minimal depth below the cutter is a most useful feature. An attractive piece of tooling.  A pretty large pile of swarf after turning that, I should think, looks like it came from 1 1/2" bar...?
 On my Myford S7, I have drilled and taper reamed a hole in the base of the swiveling top slide and through into the cross-slide, (having set up previously for turning a Morse taper of course! ) so that I can now set the taper angle for No 2 Morse just by tapping a taper pin into the two lined up holes.  Handy if you are making up an assortment of tooling for the mill, etc. over a period of time.  ( Though if you have a proper taper turning attachment......)
« Reply #8 on: June 16, 2016, 10:25:40 AM »
Nice one Pete and I also like the way you did it.  Which now reminds me that I have two 3MT blank arbors which I got for this purpose but never actually did them.
Online toolznthings
  • Kent,Ohio
« Reply #9 on: June 17, 2016, 01:59:48 AM »
Another, Nice job !  :ThumbsUp:
Brian
Thanks for the visit !
Brian
Online 10KPete
« Reply #10 on: June 17, 2016, 04:09:59 AM »
And here is what I used it on first:
Online 10KPete
« Reply #11 on: June 19, 2016, 01:37:03 AM »
Added pics.
« Reply #12 on: June 19, 2016, 08:33:49 AM »
Another useful tool  :ThumbsUp:  :ThumbsUp: Is the big 'foot' on the DTI a standard accessory?
Offline Steamer5
  • The "Naki" New Zealand
« Reply #13 on: June 19, 2016, 09:15:18 AM »
Hi Pete,
 Nice tools.....the to do list just grew some more!
Cheers Kerrin
Online 10KPete
« Reply #14 on: June 19, 2016, 01:33:34 PM »
The large 'button' is available I think, but I make my own as they are a really simple lathe job. I make them out of whatever material desired (I don't worry about hardening). The standard AGED indicators have a 4-48 female thread so that's easy. I just eyeball most dimensions to suit the need.
I  make 'em large, small, long, short, whatever. I think I made that one to span gear teeth....
