Author Topic: Gear Tooth Chart  (Read 3124 times)
Gear Tooth Chart
« on: June 11, 2016, 12:55:19 AM »
Gear tooth gauges are available but are extremely expensive, like $100 for a set. Can't afford that nor do I need
those. Silly prices for some bits of stamped sheet metal!
Where can I get a printed, or printable, gear tooth chart I can use to identify various gear pitches? I've been all over Google with no joy. I just need something I can hold a gear up to and identify what the pitch is.
Anyone?
Re: Gear Tooth Chart
« Reply #1 on: June 11, 2016, 01:09:29 AM »
Check Ebay....I just did, and I found prices from 4 dollars to 200 dollars......somewhere in there is one you can stand to pay for....
« Reply #2 on: June 11, 2016, 07:49:24 AM »
Boston Gear show the tooth size of the various DPs
http://www.altraliterature.com/pdfs/P-1930-BG.pdf
« Reply #3 on: June 11, 2016, 03:17:20 PM »
Why not use the formula?
DP = (N+2)/OD
« Reply #4 on: June 11, 2016, 05:27:17 PM »
Doesn't tell you the pressure angle Marv....though you can usually "Guess"
« Reply #5 on: June 11, 2016, 05:37:39 PM »
Pete's original post says,
"Where can I get a printed, or printable, gear tooth chart I can use to identify various gear PITCHES?"  (Emphasis mine.)
If he wants pressure angle, he can use the program on my page (GEARPA).  Several machinists have used it and given me favorable reports.
« Reply #6 on: June 11, 2016, 09:19:09 PM »
As usual Marv you are quite correct...however, having the gage set lets you interrogate the gear in question where ever you may be....and sometimes that doesn't include a computer with your program on it....
« Reply #7 on: June 12, 2016, 02:54:22 AM »
Well, thanks for the suggestions. I'm looking for a 'profile chart' that I can hold up to a gear and determine its' pitch.
Google is rife with charts but none provide scale information so they can't be printed accurately. Useless!!
I'll continue to look and I suspect I'll contact some gear companies in the hope one can provide a printed, or print-able, chart. Maybe in a catalog.
Thanks,
