Author Topic: Red Wing Number 1009  (Read 6852 times)
Offline Albertdewitte
  • Try to be precise
« on: June 08, 2016, 12:38:33 PM »
Hi guys
This is my Red Wing completed yesterday.
« Last Edit: June 08, 2016, 01:13:10 PM by Albertdewitte »
Offline Ian S C
Re: Red Wing Number 1009
« Reply #1 on: June 08, 2016, 01:24:27 PM »
Looks good, the photos are a bit big for me on dial up, I'll have a look on broadband when I'm at the library tomorrow.
Ian S C
640 x 480 is a good size
Offline Flyboy Jim
  • Independence, Oregon
« Reply #2 on: June 08, 2016, 01:55:39 PM »
Very nice work!  :ThumbsUp:
I enjoyed to video of it running as well.
Sherline 4400 Lathe
Sherline 5400 Mill
  • Try to be precise
« Reply #3 on: June 08, 2016, 02:03:19 PM »
Jim and Ian
Thanks for the compliments!!
There is a video of the unpainted engine on youtube: <a href="https://www.youtube.com/watch?v=-qWIcE_Bl5Y" target="_blank">http://www.youtube.com/watch?v=-qWIcE_Bl5Y</a>
I will hopefully make the video on Saturday when I have proper sunlight.
Regards
« Reply #4 on: June 08, 2016, 02:25:53 PM »
Albert, can you comment some on the painting....type of paint, applications process, etc. It turned out well and for many of us is or can be a problem area.
  • Try to be precise
« Reply #5 on: June 08, 2016, 02:47:26 PM »
Hi Bill
With pleasure
The important part is to clean all surfaces first to be oil and grease free where I use Plascons silicon and oil remover which must dry for about an hour.
The next step is to prepare the surfaces.
The casing had a lot of uneven surfaces where I primed it first then added body putty and sanded it down. Then another coat of primer sanded with 600grit.
All other parts were painted also with 2 coats of primer with light sanding in between
I normally use what we call here 2K, base with hardner from Plascon.
I use the 1-1-2 mixture. (1 thinners 1 hardner and 2 parts of base color)
Before I start spraying I check the humidity. Even with the water trap if its more than 40% I had some water droplets on the finish on other engines before that can really ruin your work.
Then I apply up to 6 coats of paint, spraying about 10 minutes intervals.
This leaves a beautiful shiny finish. No polish is required.
Most important: the area must be well ventilated with no dust or flies.
All the above is experience I gained when I was still building model aeroplanes.
The final paint job must be left for about 4 days for the paint to cure properly before assembly, pending temprature.
I hope this helps
« Reply #6 on: June 08, 2016, 08:49:08 PM »
Albert nice work on the engine and a great paint job. Thanks for the tips on painting, it will be something to remember.
I think Dog will do us proud also when he finishes his...... :ThumbsUp:
« Reply #7 on: June 08, 2016, 11:26:18 PM »
Hi Albert
A very handsome engine for sure - you must be proud.
« Reply #8 on: June 09, 2016, 12:21:31 AM »
Wow! The flywheels are great! I mean really...there's few times you see so little wobble. It's like the rim is stationary.
« Reply #9 on: June 09, 2016, 01:15:11 AM »
Beautiful engine Albert!
  • Try to be precise
« Reply #10 on: June 09, 2016, 06:55:39 AM »
Dave, zeeprogrammer, Admiral_dk and Don
Thanks all of your for the commends. Really appreciated.
Like always last night I did some final touches on settings etc and let it run for about an hour.
I decided to make a little video again and I managed to upload it.
See the vapor on the hopper. What is amazing here is that the engine does not get that hot. I can hold the muffler with my bear hands.
Enjoy
<a href="https://www.youtube.com/watch?v=TV6S64xReiU" target="_blank">http://www.youtube.com/watch?v=TV6S64xReiU</a>
« Last Edit: June 09, 2016, 07:57:18 AM by Albertdewitte »
Offline Steamer5
  • The "Naki" New Zealand
« Reply #11 on: June 09, 2016, 09:55:19 AM »
Hi Albert,
 That tinkering has paid off! She runs very sweet!
Cheers Kerrin
« Reply #12 on: June 09, 2016, 11:48:52 AM »
Sweet indeed Albert!!  It runs as good as it looks!!
  • Try to be precise
« Reply #13 on: June 09, 2016, 12:45:35 PM »
Thanks Bill and Kerrin!!
Offline Alan Haisley
« Reply #14 on: June 09, 2016, 04:09:28 PM »
I love the hit-miss sound. Great choice of paint, too.  :ThumbsUp:
Alan
« Reply #15 on: June 09, 2016, 05:41:17 PM »
Excellent build Albert and very sweet running engine to boot.
« Reply #16 on: June 09, 2016, 05:56:11 PM »
Very nice indeed  :praise2:  :praise2:  The fine tuning certainly improved the running  :ThumbsUp:  :ThumbsUp:
« Reply #17 on: June 09, 2016, 11:06:25 PM »
Albert,  sorry for checking in so late;  I have been on the road doing a 1:1 scale antique auto thing.  The build looks wonderful,  the paint is awesome,  and it runs like a sewing machine  :ThumbsUp: :ThumbsUp: :cheers:. I only hope to achieve close to this.  Again,  a great job.
Cletus
P.S. what color green is that?
« Reply #18 on: June 10, 2016, 12:15:50 AM »
Are you home yet Cletus?
« Reply #19 on: June 10, 2016, 02:01:34 AM »
Yup, just putting out fires from the boss being away  :censored:
Cletus
  • Try to be precise
« Reply #20 on: June 10, 2016, 06:37:09 AM »
Thanks Alan
Offline yogi
  • Duncannon, PA USA
    • Yogi's Workshop
« Reply #21 on: June 11, 2016, 01:51:25 AM »
Fantastic engine Albert!  :ThumbsUp:
Thanks for sharing.  :cheers:
« Reply #22 on: June 11, 2016, 07:00:19 AM »
Hi Albert, a very smooth runner. A pleasure to watch and also I do like the hit and miss sound.
  • Try to be precise
« Reply #23 on: June 12, 2016, 08:50:40 AM »
Thanks Alan :)
Database Error
Back
