Author Topic: Small indexing head upgrade and fit out.  (Read 10027 times)
Re: Small indexing head upgrade and fit out.
« Reply #15 on: June 11, 2016, 11:21:29 AM »
Now I've got me head wrapped around it :smokin2: For some reason I thought you were going the other direction. I made something similar for my RT wit a MT2 shank.
Cletus
« Reply #16 on: June 11, 2016, 06:02:18 PM »
Size Dave, photo image size  :stickpoke:
Promising as it looks using more pixels won't help the guys see and appreciate you work any quicker  :ShakeHead:
« Reply #17 on: June 18, 2016, 09:12:56 PM »
OK. Between yelling at the TV about the GT shunt, I'm rough turningthe spindle.       Setting up the fixed steady to bore one end.
« Reply #18 on: July 04, 2016, 08:05:24 PM »
OK   Bored and reamed the back of the spindle to size.   Now to finish the OD, then flip and machine the spindle nose and collet bore
Pictures to come!    IM IN MY SHOP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! :pinkelephant:
« Reply #19 on: July 04, 2016, 10:47:45 PM »
Pretty fun, isn't it Dave :)
When you don't get out there much, it makes you appreciate it all the more!
Glad you're getting some shop time!
« Reply #20 on: July 04, 2016, 11:26:41 PM »
Glad you are getting some shop time Dave. But yes, we need pictures please!!
« Reply #21 on: July 04, 2016, 11:33:19 PM »
Waiting for the pictures my brother and sure glad to see you getting the shop time in...... :ThumbsUp:
« Reply #22 on: July 05, 2016, 12:02:59 AM »
Bored and reamed the internal    That's the back of the spindle.
Then put between center and finished the OD of the spindle.
Nailed the diameter....within about .0004"        Now we flip it, and put the front in the steady rest and grab the rear in the 4 jaw with some soft metal packing and cut the spindle nose 1 1/2 -8 thread and the 3C collet internal.   Then I'll set up and put the anti rotation pin in and be done.
« Reply #23 on: July 05, 2016, 02:38:34 PM »
Maybe Im just out of practice, but it took an hour to get that shaft to not runout at the chuck and not crank at the far end.....PITA!....but it's done....on with the machining of the front!
« Reply #24 on: July 05, 2016, 05:36:04 PM »
Sweetness!     3C features are in,.....now for the thread!   1.496-8 with a 1.510 register diameter....Register first.
Pictures coming
« Reply #25 on: July 05, 2016, 05:45:15 PM »
While I make some lunch, I ordered up a 12" long piece of 3/4" OD x .120" wall DOM tubing for the draw bar.    No need to hog out solid stock for this even if it is short.
Ill need a knob on the end, so I figured I'd copy the ER32 collet chuck nut dimensions so I don't need anther wrench.
Major work being planed to clean and reshuffle the shop this week too...
« Reply #26 on: July 05, 2016, 06:54:57 PM »
What did you have for lunch  :lolb: :lolb:. Man it is great to see Samantha all oiled up in the summertime  :mischief: :naughty:. Is this spindle going to be Moore quality  :stir: :stir: :lolb:
Cletus
« Reply #27 on: July 05, 2016, 08:56:32 PM »
Wellll runout it's awesome.....the thread didn't come out so nice, but it works just fine and the chuck register is perfect so I'm leaving it be
...needs to have the index barrel pinned on and the collet pin put in and a draw bar made
« Reply #28 on: July 05, 2016, 10:18:04 PM »
Looks great to me Dave.......... :ThumbsUp:
« Reply #29 on: July 06, 2016, 12:32:50 AM »
Looking good Dave!  :ThumbsUp:
Glad to see that you are getting some shop time.
