The Deckel Collet AdventureThe Deckel SO T&C grinder uses U2 collets.
Not only do they have a fairly narrow grip range, but the Made by Deckel collets are almost $100.00 USD each. (1/32” increments).
The Made in Taiwan collets at $29.00 each only come in 1/16” increments.
My SO came with the standard set of Deckel collets from .125 - .6875 in 1/16” increments. BTW, a new, standard Deckel set is $600.00.
Of course, the first few pieces from my extensive collection of broken tap shanks didn’t fit. Too loose or too tight.
What to do? Here’s my solution.
An ER20 straight shank holder to fit the .6875 Deckel collet.
A set of ER20 collets.
Holder and collet set from eBay. Total $36.00
The ER20 holder
The Collet set
The holder was inserted into a 5C collet from the rear. Amazingly, it was a perfect fit to the inside of the 5C.
Then, parted to reduce the shank length.
Fitted into the Deckel collet.
Then, into the Deckel.
And, it does work. The only issue, which I think I have a solution for, is the small squaring alignment gauge. Certainly not a deal breaker.
Final note: the Deckel Square collets are $300.00 each. The fix is in on holding square tool bits thanks to a Harold Hall article.More on that later. No, I’m not a big fan of putting a square into a round collet.
