Yeah, but then you have to crane your neck to see around back
True enough Marv, but I still check the back too. A little mirror can help too.
Quote from: b.lindsey on July 26, 2016, 11:23:42 PMYeah, but then you have to crane your neck to see around backI don't think that's true. Given a truly round workpiece, if the DTI readings left, right and front are the same the back reading MUST match.
Quote from: mklotz on July 27, 2016, 03:11:20 PMQuote from: b.lindsey on July 26, 2016, 11:23:42 PMYeah, but then you have to crane your neck to see around backI don't think that's true. Given a truly round workpiece, if the DTI readings left, right and front are the same the back reading MUST match.Marv, thanks, once again, for pointing out what should have been obvious. I'm not sure how long it would of taken me to make that little discovery on my own. Now, that said, I think I may be like Bill and have a hard time letting go of that 4th measurement (the back).Jim
