Author Topic: Saving surface of new fixture plate .....  (Read 1689 times)
toolznthings
« on: April 21, 2016, 09:02:41 PM »
Hi All,
Just made a new sub plate for my mill to fixture a part to mill the outside contour, but did not want to cut into the new plate. Plate is made from M6 tooling plate. Part needed to set flat so I applied laminate counter top material with double side tape in the area I was going to cut. The thickness of the material is very uniform, within a .001" or .002 at the worst. I just cut deep enough to finish the sides of the part. Held up fine using spray mist. Saved the surface for another day. Picture showing the cut into the laminate.
Brian
