Where possible, I like to turn a shallow groove around the shaft in the way of the set screws. Not deep, but enough that any burr raised by the screw won't interfere with the bore of the (insert item name here). The item can be positioned at any rotation and the groove takes care of any burrs.
Where possible, I like to turn a shallow groove around the shaft in the way of the set screws. Not deep, but enough that any burr raised by the screw won't interfere with the bore of the (insert item name here). The item can be positioned at any rotation and the groove takes care of any burrs.Pete
