Author Topic: Vince's version of the Monitor Steam Engine  (Read 139999 times)
Offline sshire
    • LS Editions
Re: Vince's version of the Monitor Steam Engine
« Reply #495 on: March 29, 2017, 01:32:44 PM »
I was concerned that the set screws(grub screws) would dimple the shaft so I didn't really tighten down on them too hard. Bad idea. At Cabin Fever, after running for an hour, the eccentric slipped and the timing went down the tubes.
When I got home, I disassembled and filed flats. Highly recommended.
Also switched from the standard cup-point to flat point. Better on a filed flat.
Don't know about your suppliers but McMaster-Carr has them in metric and imperial. Alloy steel and stainless steel.
I did have a fleeting thought to use extended point set screws which are designed to lock into a mating hole on the shaft.
Best,
Stan
Offline bruedney
  • Wellington, New Zealand
« Reply #496 on: March 29, 2017, 07:02:00 PM »
I used the 3 at 45deg with no flats - no problems. I suppose it depends on the load. My valve rods were binding due to the tendency to tip with only one end supported hence my redesign of valves and rods to allow for support at both side of the steam chest.
I also drilled and tapped the 2 halves and added a 3mm screw just to make sure the loctite didn't let go. I cut the heads off and filed flat
Looking good though Vince
Bruce
« Reply #497 on: March 29, 2017, 09:32:37 PM »
Thanks gents for the comments and suggestions.
I have to think about it.
« Reply #498 on: March 29, 2017, 09:42:50 PM »
Where possible, I like to turn a shallow groove around the shaft in the way of the set screws. Not deep, but enough that any burr raised by the screw won't interfere with the bore of the (insert item name here). The item can be positioned at any rotation and the groove takes care of any burrs.
Offline sshire
    • LS Editions
« Reply #499 on: March 29, 2017, 10:29:29 PM »
Good one, Pete.
Best,
Stan
« Reply #500 on: March 30, 2017, 12:06:53 AM »
Nice idea! Thanks.  :ThumbsUp:
« Reply #501 on: March 30, 2017, 01:44:23 AM »
Looks like you are in the home stretch Vince. That last family shot looks terrific too!!  Looking forward to seeing it run.
« Reply #502 on: March 30, 2017, 03:46:56 AM »
Well geeez...........file that in the "why didn't I think of that" category! Good one Pete.  :ThumbsUp:
« Reply #503 on: March 30, 2017, 10:55:26 AM »
Good idea Pete.  Have to keep it in mind.
« Reply #504 on: April 01, 2017, 06:01:36 PM »
More work on the eccentric sheaves.
With the help of a 10 mm rod in the tailstock I put the sheave in the 4 jaw chuck and carefully tightened the jaws.
Made a quick check on runout.  Showing 0.1mm.  Good enough for me as the next operation does not require lots of accuracy.
Started machining the shoulder around the 10mm hole.
Both of them finished.
Next for the final operation which will be drilling and tapping the three 3mm holes for the grub screws.  Decided to make them as per plans; i.e. with 45 degree spacing.  Realised that doing this will not be as simple as I anticipated.  Will have to sleep on it.
« Last Edit: April 01, 2017, 08:59:41 PM by vcutajar »
« Reply #505 on: April 01, 2017, 07:45:39 PM »
 :ThumbsUp:
Almost there!
Offline sshire
    • LS Editions
« Reply #506 on: April 02, 2017, 01:07:55 AM »
The suspense is killing us
Best,
Stan
« Reply #507 on: April 02, 2017, 01:22:21 AM »
The eccentrics and sheaves turned out great Vince of coarse I expected no less buddy. Still with you and enjoying it....... :ThumbsUp:
« Reply #508 on: April 02, 2017, 01:38:54 AM »
Beautiful looking assemblies Vince. Things should be getting close now !!
« Reply #509 on: April 02, 2017, 05:33:28 PM »
Thanks guys for keeping me company.
So today I took the dividing head out to drill the holes for the grub screws.  Drilled the first one and started tapping the holes.  The taps were not cutting too well.  I guess the material got work hardened when drilling and the taps are not sharp anymore because on the last hole I broke a tap.  Disaster, as I could not get the broken part out.
After a siesta I went back to have another look at the situation.  I could make a new part or use the one I had with two grub screws.
Eventually I found I had a small carbide burr with a taper shape.  Let's give it a try.  It actually worked as it started breaking up the broken tap in the hole.  With a little patience and a hardened 2mm pin punch I managed to chip it all out.
Phew.  Managed to save the part.
« Last Edit: April 02, 2017, 09:07:13 PM by vcutajar »
