Quote from: zeeprogrammer on April 18, 2016, 11:01:18 AM Slots? What slots?Zee - the slots in the 25 x 25 base frames for the inner frames to slot into.
Slots? What slots?
Quote from: zeeprogrammer on April 18, 2016, 11:01:18 AMI'm sure you already know...but for some of us...that's the back of the engine.And I haven't quite figured out which way is which yet.
That's a great idea. Did not think about it. Must be a carbide endmill. They usually have the shank diameter the same as the cutting diameter. Must find one pronto.Vince
I think I just told you.
Doesn't look too bad even if I do say so myself
I'm wondering about the rear crankshaft bearing. I thought the collars went inside between the frames. Maybe it doesn't matter.On mine, the bearing doesn't stick out so far and if I put the collar on the outside (i.e. next to flywheel) then bearing doesn't stick all the way through the collor.Just wondering if there's enough clearance for the flywheel and crank.The assembly drawing shows the front collar between the two front frames. I can't see the rear one.
