Author Topic: 1144  (Read 2950 times)
Offline gldavison
  • Tarkio, Mo.
1144
« on: April 10, 2016, 12:30:09 AM »
Why is this stuff only available in round stock??
At least I have not found it in anything but round.
Gary
Windows 10 & 11, Alibre Design Pro V27, IntelliCADPro6, CamBam, Mach4, 3D Printers, Cetus, Anet ET5 X
15" South Bend, 10" Logan lathe, Grizzly square column mill, CNC router & Hot wire cutter. Lagun FTV-1 knee mill, Sherline mill & lathe
Re: 1144
« Reply #1 on: April 10, 2016, 12:40:31 AM »
If you can get 'em to supply in square or flat you'll be a Saint among ME's!!
It's primary use is in turned products off automatic machines I think.
Offline PStechPaul
  • Cockeysville, MD 21030
Re: 1144
« Reply #2 on: April 10, 2016, 06:36:38 AM »
You can get it in hexagonal bar:
https://www.castlemetals.com/metals/carbon/1144/c/1144
The following source has round, square, and flat plate:
http://www.steelss.com/Carbon-steel/sae-1144.html
Re: 1144
« Reply #3 on: April 10, 2016, 07:39:40 AM »
Last time I made inquiry at Castle, about five years ago, they didn't cut one-off short pieces nor have anything but full bars. Of anything.
Steelss is a mill in China. I doubt you'll get home shop bits from them either.
Come on, Paul!
Offline PStechPaul
Re: 1144
« Reply #4 on: April 10, 2016, 11:16:06 PM »
There are some sources of 1144 hex rod on ebay:
http://www.ebay.com/itm/1144-STRESSPROOF-STEEL-HEX-BAR-STOCK-machine-shop-rod-1-3-4-x-12-long-/351222388389
I hadn't noticed that the other source was in China, but they might send you a sample if you request a quote for "shipload" of the stuff.
It seems to be mostly for shafts, pins and axles and other round items
Apparently there is also a specific stressproof steel that may be superior to 1144:
http://www.practicalmachinist.com/vb/cnc-machining/1144-vs-stressproof-real-thing-170784/
This might be a source for shapes other than round and hex:
http://amsresources.com/1141-1144-1145-resulfurized-carbon-steel/
Apparently 1144 is not necessarily stressproof or stress-relieved, although it usually is assumed to be:
http://www.bhpipe.com/1144-Stressproof-equivalent-steel.htm
http://www.icimetals.com/metals_carbon_alloy.htm#group8
http://www.niagaralasalle.com/product-stressproof.html
http://www.eng-tips.com/viewthread.cfm?qid=115693
At least now I know a lot more about 1144 and stressproof steel  ;)
Offline GailinNM
  • Albuquerque, NM, USA
Re: 1144
« Reply #5 on: April 11, 2016, 03:24:55 AM »
It is used quite often in Swiss style CNC automatic lathes.  They require close tolerances on the stock diameter so  the 1144 is available as TGP which means Turned-Ground-Polished.  Typical diameter tolerance is +.000/-0.001 inch. This makes it very useful for shafting and making small parts.
Depending on diameterl it costs about twice what cold finished 1144 does but for as little as I use I find it very cost effective.
Gail in NM
Offline gldavison
  • Tarkio, Mo.
Re: 1144
« Reply #6 on: April 11, 2016, 11:54:53 PM »
Speaking of cost.  I was searching for a 12 inch piece of 1-3/4 round. Found it at Cal-Mesa in Yucaipa, Ca.  They wanted 30 dollars a foot plus 10 dollar cut charge. But he says  he has a 37 inch piece for a 50.  Guess what I came home with?
Gary
Re: 1144
« Reply #7 on: April 12, 2016, 12:30:02 AM »
Quite a deal I would say. Nice find!!
