Author Topic: Band Sawing to a Layout .......  (Read 1681 times)
toolznthings
« on: April 05, 2016, 10:49:57 PM »
I came up with this simple trick that I've been doing for years. Makes sawing to a line much easier when doing work on a band saw. Most kerf widths vary between 1/16" and 3/32". Knowing what width your blade kerf is draw a parallel line to your layout. Sawing between the two lines is much easier and more accurate. The layout can usually be just " eye balled " and quickly done. Give it a try.
Sawing thru 1 7/8" thick mild steel .....
Re: Band Sawing to a Layout .......
« Reply #1 on: April 05, 2016, 11:48:25 PM »
Interesting trick - will try to remember it next time - thanks.
« Reply #2 on: April 06, 2016, 02:20:39 AM »
Its a good technique, I've been doing that recently when hacksawing or recip sawing out bar stock, definitely easier to eyeball between the two lines without drifting off one.
Online Dave Otto
« Reply #3 on: April 06, 2016, 02:30:46 AM »
I'm working on a large cross section at the day job, that involves using the big Doall band saw and a diamond blade. I may give this a try to see if it improves my band saw driving skills. :lolb:
Thanks,
Offline Flyboy Jim
  • Independence, Oregon
« Reply #4 on: April 06, 2016, 02:54:26 AM »
Great idea................I'll give it a try.
Thanks, Jim
Sherline 4400 Lathe
Sherline 5400 Mill
