With a 3K spindle contra rotating gears in constant mesh well I will let you ponder that one
I hadn't heard of Tufnol before. Looked it up to see that it's some kind of laminated plastic.But I'm wondering about a couple of other terms...'dog gears' and 'dog clutch'I know gear and clutch. What does it mean to qualigy with 'dog'?Thanks
BjornHave fun but do read the book carefully with regard as to the indent ball for the selector 😬😬😬😬 Gray lost his down the hole but I did not 😀Stuart
I must concur with Stuart, beware the detent ball does not escape. For those who would like to disengage the clutch when working on hi RPM, Ken Willson did an indexer unit that bolts to the back of the clutch body. This utilises the redundant tumbler reverse quadrant holes. The Red indexing knob in the second picture of attached article can just be made out.www.modelengineeringwebsite.com/Screw-cutting_clutch.html
I see Gray has saved me the job of posting the modified version Ken
