I used a 1.123 dia 32 DPD x 24 teeth on the side shaft, and 12 teeth gear on the crank shaft, the gears are from HPC, the valve gear is made as the drawings show the inlet pushrod is slightly off perpendicular which makes no difference to the running of the engine.
Mike.
