Author Topic: Personal variant of Yarrow boiler  (Read 7055 times)
Offline Malevthi
    • BloOOo Forum
« on: March 29, 2016, 10:49:33 PM »
Hello,
My current project is a personal variant of a Yarrow boiler :
To be continued ...
« Last Edit: April 15, 2016, 07:36:07 AM by Malevthi »
Re: Personal variant of a Yarrow boiler
« Reply #1 on: March 29, 2016, 11:03:28 PM »
Very nice work Malevthi.
« Reply #2 on: March 30, 2016, 12:00:31 AM »
Wow, with all that heating area that boiler should be a real high producer! Beautiful work.
Offline yogi
  • Duncannon, PA USA
    • Yogi's Workshop
« Reply #3 on: March 30, 2016, 01:43:26 AM »
Fantastic work! Very interesting!   :ThumbsUp:
I'm hoping to see more. Thanks for sharing.  :cheers:
« Reply #4 on: March 30, 2016, 07:09:18 AM »
 8)
I was a little worried when I spotted those std plumbing corners but then realised that it was just a support jig while you were doing the silver soldering of the tubes.
What sort of pressure are you planning to run this at Thierry?
Offline paul gough
« Reply #5 on: March 30, 2016, 07:41:32 AM »
Bonjour Thierry, This is an interesting variation on the Yarrow type. Your pipe bending appears precise. As you solder into the drum first rather than form the tubes first, could you show and describe your method. Also, it would be helpful if you could provide dimensions. While we have to follow our respective countries boiler codes it would be good to know sizes so we can appreciate the proportioning as an aid to designing our own. What size engine, (cylinders), do you consider this boiler capable of supplying continuously? Regards, Paul Gough.
Offline Malevthi
    • BloOOo Forum
« Reply #6 on: March 30, 2016, 05:11:37 PM »
Hello everybody,
I bent the tubes one after one on a half cut hard wooden pulley.
I work about 50 psi with feed pump and 15cc engine or turbine.
« Last Edit: March 30, 2016, 05:33:10 PM by Malevthi »
Offline Zephyrin
  • near Paris, France
« Reply #7 on: March 30, 2016, 06:39:28 PM »
Awsome work, congratulation et salut Thierry !
There is something I dont get in the way the small water tubes are bended around the main boiler and how the rectangular frame is removed ?
Offline Malevthi
    • BloOOo Forum
« Reply #8 on: March 30, 2016, 09:42:18 PM »
Salut Zephyrin,
The rectangular frame is cut and removed before bending tubes.
Offline Sackett
Re: Personal variant of Yarrow boiler
« Reply #9 on: April 30, 2016, 11:34:29 PM »
nice yarrow boiler,,,should make a lot of steam fast.I ran a full sized one at a sawmill once,,, easiest fireing boiler I ever ran
« Reply #10 on: May 01, 2016, 07:51:54 AM »
An impressive soldering job. Thanks for showing the details.
Offline Malevthi
    • BloOOo Forum
« Reply #11 on: July 04, 2016, 05:31:50 PM »
Follow-up :
<a href="https://www.youtube.com/watch?v=h_EG231TyrI" target="_blank">http://www.youtube.com/watch?v=h_EG231TyrI</a>
Offline Johnb
  • John Browning, IDSME
« Reply #12 on: July 04, 2016, 07:44:02 PM »
Nice work.
Offline Malevthi
    • BloOOo Forum
« Reply #13 on: July 05, 2016, 04:21:40 PM »
Céramic burner:
Offline yogi
  • Duncannon, PA USA
    • Yogi's Workshop
« Reply #14 on: July 05, 2016, 11:02:55 PM »
Very impressive boiler! Well done! :ThumbsUp: :ThumbsUp: :ThumbsUp:
Thanks for sharing.  :popcorn:
