Gcmc is a front-end language for generating G-code, SVG and DXF for CNC mills, lathes, laser cutters and other numerical controlled machines employing G-code, SVG or DXF. The language is a context-free grammar created to overcome the archaic format of G-code programming and aims to be more readable and understandable. Gcmc makes extensive use of vector mathematics to support the 3D nature of CNC machining.An introduction document is available. The introduction goes through basic syntax and program outline and describes an example to create involute gears in under 200 lines of code (under 100 lines when excluding source code comments).
Well, after smashing my zeroing tool into my vise and having to reset the zero on all of my tools, I am finally back in business.
