More opportunity for fun! I appreciate the description you gave on boring and the 'troubles' you had. That kind of stuff really helps newbies like me to a) recognize when it happens and b) know what to do to overcome.Hope you have enough cookies to last the project.
If your '303' is the same as our EN58 ( I think it is close, without checking ) it work hardens. So, your last cut needs to be over some 0.002" otherwise it just tend to push the tool off.There used to be a variant of EN58 ( with a 'J' suffix IIRC ) which wasn't so intractable.You might find it cuts better with a HSS tool for the last skim. It needs to be newly ground and honed and you'll only get one pass. Dave
Quote from: Bluechip on March 19, 2016, 08:31:58 PMIf your '303' is the same as our EN58 ( I think it is close, without checking ) it work hardens. So, your last cut needs to be over some 0.002" otherwise it just tend to push the tool off.There used to be a variant of EN58 ( with a 'J' suffix IIRC ) which wasn't so intractable.You might find it cuts better with a HSS tool for the last skim. It needs to be newly ground and honed and you'll only get one pass. DaveHi Dave,Nearest I can find is a chart that shows the 303 is simaler to the EN58-AM version, some of the other EN58 versions are like the 302 or 304 steel here. Gotta love standards, everyone has them, and nobody shares!I have used a lot of 303, never had any work hardening issues with it while machining so far. For this bore I went from a 3/8" starting hole, all the way out to about 1" with multiple passes with the boring bars before having any issues. I am using carbide inserts on the boring bars, and cobalt alloy drills. changing the cutter position and speed seemed to help a lot as the hole got larger. When cutting in the shoulder on the outside (also with carbide insert cutter), had no trouble there at all, it cuts very easily.
I have heard that the EN prefix for steels refer to Emergency Number this was brought ab out in the first world war to clarify the different steels used for the weapons industry etc , Please correct me if i am wrong thanksWilly.
Chris,This is great to be able to start following along right at the start of your build. I've learned a lot from your build threads, seeing how you deal with making various parts on your Sherlines.Jim
For picking the end mill, have questions for you guys: for milling down the side of the plates (1/2+ thick) with the side of the mill, does it matter which diameter mill that I use? Any difference in the finish I will get from a 1/4" vs a 3/8" mill on 303 stainless steel? Are there rules of thumb for this, like there are for picking tooth count on a saw for different thicknesses of stock?
