Great progress Nick. At this rate you will finish it in no time.
Not 100% sure about that Vince.
I am planning to make some deviations from the drawing to make this as Jason termed it a 'Nicklet' - i.e. make it basically the important bits as per drawing and then some deviation to make it my own.
This (as planned) is as follows :-
Make a 'proper' crank with 2 split bearings and dogleged con rods to bring them back into line with the bores. I am not a fan of the Harley big end layout. I know that to an American that is equal to insulting
'Moms apple pie' and all things wholesome. If I was American I would be shot for being unpatriotic.!
- Especially if I was in Texas.
I will then make a larger dia and wider fly wheel and thus place it outboard of the skeleton crankcase. Hopefully this will make for a nice slow tickover.
The crankshaft mains will run in 3 possibly 4 ballraces.
I am sure that I will not be the first to alter the iconic V layout. After all the classic Harley engine was designed (I have been told) in 1936 as a water pump engine. So it was probably originally adapted as a utility engine in many applications before it was made
infamous famous
by Harley Davidson.
Anyway. I am really enjoying the build and am very appreciative of the vital assistance I am getting.
Nick
