All the ones I purchased have the AF measurement listed, I just don't believe the measurements.Here's one example for 1-64:http://www.amazon.com/gp/product/B009EEX2G2?psc=1&redirect=true&ref_=oh_aui_detailpage_o01_s01It lists the AF width as 3/64.American Modeling lists hex used as 7/64 for 1-72.
So then Jo if I set a feed of 0.002 inches will I cut a 500 tpi thread assuming my eye sight and quorn can grind the tool bit be interesting to use the thread dial
Yes Mr Silky has one of those and six different positions for thread starting. Not that I can think why you would want a six start thread
Quote from: Jo on March 12, 2016, 08:14:13 AMIt depends if you have ground your tool for cutting a thread with a flat crest or sharp Cutting the external threads is easy enough; it's grinding the boring too to do the internal thread of that LH 17BA nut that gets a bit tricky...AS
