What would be the thread depth on something that fine?
250 TPI is a threading rate not surfacing. I thought the Warco machines only went down to 80 Tpi .Jo
..............but I thought that all lathe work cut a spiral...............
It depends if you have ground your tool for cutting a thread with a flat crest or sharp
Quote from: Jo on March 12, 2016, 08:14:13 AMIt depends if you have ground your tool for cutting a thread with a flat crest or sharp Cutting the external threads is easy enough; it's grinding the boring too to do the internal thread of that LH 17BA nut that gets a bit tricky...AS
I expect all the ones you have ordered will be larger hex than American Model Eng as they are the modern mass produced ones. I too have a supply of these as they are ones supplied with various models that just look horrid so I substitute them with something more in keeping.
I will not buy any hex fastener for model work that does not list the AF hex size. The thread I linked is sources of model hex bolts or other small useful small fasteners.The selection is not as good at Microfasteners but they do stock a selection of small pattern hex nuts and bolts and they do list the hex size so you know what you will be getting.Here is the choice of small pattern SS nuts:http://www.microfasteners.com/small-pattern.htmlDan
Was that a Typo ?as 27BA would be nearer to Jo's 250tpi
17BA is 149 1/2 TPI, but for some reason that is not a standard pitch for Mr Silky .
