Author Topic: 1867 Otto and Langen Free Piston Engine  (Read 44283 times)
Offline Flyboy Jim
  • Independence, Oregon
Re: 1867 Otto and Langen Free Piston Engine
« Reply #90 on: June 23, 2016, 02:59:03 AM »
Stunning............a master at work!  :praise2:
Sherline 4400 Lathe
Sherline 5400 Mill
Offline Steamer5
  • The "Naki" New Zealand
« Reply #91 on: June 23, 2016, 07:30:11 AM »
Hi Dave,
 Stunning work! One day maybe........I can dream......
Cheers Kerrin
Offline mnay
« Reply #92 on: July 11, 2016, 07:31:20 PM »
He is a true artist.
Beautiful work.
« Reply #93 on: July 26, 2016, 12:33:43 AM »
Bill, Yogi, Don, Kerrin, & mnay
Thanks for all the nice comments and your continued support. I have been needing to get an update posted; it seems that Max is able to crank out parts faster that I can get them posted. :lolb:
He has been busy as you can see the progress photos.
The eccentric straps were next and they are each different. After the blanks were screwed together they were bored in the mill.
Then transferred to the lathe to cut the locating groove in the ID of the bore. The two mounting holes used to hold the part to the mandrill were located in areas that would later be removed. Once the strap was mounted to the mandrill it was put in the 4 jaw chuck and dialed in.
Mounted on a different mandrill the straps were then moved to the rotary table.
After much tedious cranking they're starting to look the part.
Here are the two finished straps.
The ratchet was machined on the end of a piece of round bar using the Spindex to mill the teeth; then parted off.
A pair of square headed set screws were made to secure the ratchet.
The pawl (a fussy little part) was also machined on the end of a piece of round stock then parted off at the proper thickness.
Here is a family shot of the eccentric assembly
The ratchet and pawl both have been case hardened.
The three spur gears were turned from cast iron stock and mounted on a mandrill to machine the teeth. The blanks were left oversize on the thickness to reduce flex and chatter while cutting the teeth. Then finished to print after the teeth were cut.
Here are the two shaft gears ready for the engine. I think they may get a keyway broached in them before assembly.
The clutch assembly has also been completed; I’m starting to wonder if my friend ever sleeps.  :lolb:
Here is a picture of the assembled clutch.
And just for good measure he decided to knock out the piston.
Well I think that brings us up to date. There is some rack material on order that will take some interesting modifications to turn it into the proper part.
Thanks again for following along and all you nice comments.
Max & Dave
« Reply #94 on: July 26, 2016, 12:42:06 AM »
More incredible detailed work. Wow.
 :ThumbsUp:
« Reply #95 on: July 26, 2016, 12:53:40 AM »
Indeed it is as Chris said. Thanks so much for posting an update. I suspect there is more to come :)
« Reply #96 on: July 26, 2016, 01:00:21 AM »
Thanks Chris & Bill
Bill, yes there will be more to come; I was able to get us up to date. Now Max has got to get busy and make more parts!  :lolb:
« Reply #97 on: July 26, 2016, 01:11:59 AM »
Max has set the scale high here and I am just envious of his craftsmanship........ :praise2:
Offline Flyboy Jim
« Reply #98 on: July 26, 2016, 03:49:55 AM »
Just amazing!  :praise2:
Sherline 4400 Lathe
Sherline 5400 Mill
« Reply #99 on: July 26, 2016, 06:11:12 AM »
Max & Dave, beautiful pictures of beautiful work!
Thanks for taking the time to share.
Offline Steamer5
« Reply #100 on: July 26, 2016, 06:15:26 AM »
Hi Max & Dave,
 Still following, still enjoying & still amazed at the skills!
Cheers Kerrin
« Reply #101 on: July 26, 2016, 07:43:15 AM »
Thanks for the update Dave, its good to see what can be done with just the spin indexer without the need for fancy dividing heads etc.
« Reply #102 on: July 26, 2016, 08:21:11 PM »
Hi Dave and Max, great to see this up date. The quality of the parts is brillinant, also of the pictures. Really some nice details are shown.
« Reply #103 on: July 26, 2016, 10:59:52 PM »
Max is producing some mighty fine parts there Dave. And, he does move at a good pace; reckon that squirrel is helping him :thinking:
Cletus
Offline Rivergypsy
« Reply #104 on: July 27, 2016, 01:26:56 PM »
I've only just caught this build thread, but wow, what beautiful craftsmanship - you two are really making me think I have to try harder  :ThumbsUp:
