Author Topic: Lathe Tool Height Setter  (Read 18712 times)
Offline sshire
    • LS Editions
« on: February 19, 2016, 06:49:36 PM »
Lathe Tool Setter
There are probably dozens of solutions to setting the height of a lathe tool. From the “pinch the ruler” technique to the Hardinge Height setter as well as the integrated bubble level devices.
A few years ago, I saw a variation of this tool. I honestly don’t remember where so, I can’t properly credit the designer. Although mine is simplified, It’s very accurate.
Drawings are posted in the Plans area.
None of the dimensions are critical. The .5” and .25” rods are Drill Rod (Silver Steel). The fit of the small rod in the larger rod should be a very close slip fit.
When I use mine, I replace the rounded tip of the dial indicator with a flat tip.
So, here’s how to use it.
Step one
With the height setting tool in a collet or chuck, set the D.I. to 1/2 of the smaller (removable) rod’s diameter. My rod is .25, so the D.I. is set to +.125.
Step two
Remove the center rod and place the tool under the D.I. tip.
Adjust the lathe tool’s height until the D.I. reads 0.
That’s it.
Best,
Stan
Offline CHP
  • cheers
Re: Lathe Tool Height Setter
« Reply #1 on: February 19, 2016, 06:59:56 PM »
Nice small project :ThumbsUp: :ThumbsUp:
are you using a square to make sure your tool
is perfectly 90 degree with your bead :thinking: :thinking:
I'll make one for sure  ;D
12x36 lathe,Seig7x10 lathe, Taig lathe
9x29 Mill, Emco 55 CNC mill.......
Offline sshire
    • LS Editions
« Reply #2 on: February 19, 2016, 07:04:05 PM »
What is the issue if the tool isn't at 90°? I'm not understanding that?
Best,
Stan
Offline CHP
  • cheers
« Reply #3 on: February 19, 2016, 07:34:45 PM »
It's only to give you a reference.
If it's slightly in an angle you won't have the same reading :thinking:
Offline sshire
    • LS Editions
« Reply #4 on: February 19, 2016, 07:43:17 PM »
If the tool is level, relative to the lathe bed, pivoting the tool to any angle shouldn't change the height of the cutting edge.
Being curious, I set a tool to 0, then checked at various angles by rotating the Aloris tool post. Less than .0005 difference.
Best,
Stan
Offline DICKEYBIRD
« Reply #5 on: February 19, 2016, 07:52:00 PM »
Here's the original post by this brilliant old man I talk to every day. :old: :ROFL:  Probably not the 1st guy to do it this way or the last. :cheers:
http://bbs.homeshopmachinist.net/threads/60113-Yet-another-lathe-tool-center-setting-gauge?highlight=TOOL+HEIGHT
I do check with a square each time to ensure accuracy & consistency.
"Accuracy is the sum total of your compensating mistakes."
"The thing I hate about an argument is that it always interrupts a discussion." G. K. Chesterton
Offline CHP
  • cheers
« Reply #6 on: February 19, 2016, 07:58:17 PM »
yes this is what I ment by using a square to set the indicator 90 with the bead :cheers:
Offline sshire
    • LS Editions
« Reply #7 on: February 19, 2016, 08:19:12 PM »
Of course. I thought you meant squaring the cutting tool.
I do use a square against the frame of the setting tool.
Sorry for my confusion.
I believe that is the original post  that I saw. I've searched and couldn't find it.
Thank you
Best,
Stan
Offline philjoe5
« Reply #8 on: February 19, 2016, 08:28:33 PM »
Nice, I'm going to make one. :ThumbsUp:
Cheers,
Phil
Offline DICKEYBIRD
« Reply #9 on: February 19, 2016, 09:05:17 PM »
Another cool thing I discovered is that after you've set the tool height , you can rotate the gauge 90 deg away from you, re-square it and jog the tool in or out until it's at zero again & set the offset in Mach3's tool table.  (Or whichever CNC lathe controller du joir you're using) .  Come to think of it, if you've got DRO's on a manual lathe it'd be worthwhile setting up a tool table using the same method.
Of course, that's just a repeatable starting point for all your different tools.  The type of tool, material, speed/feed etc. makes a difference in the final position of the tool tip needed to end up with a precise part diameter.  I now have 16 different QC tool holders dialed-in including a couple drill holders & a QC X-axis live drill for drilling holes from the side.  (I'm working on a QC mounted TPG right now that will need to be dialed-in too.)
That gauge tool sure makes the the setup a lot easier!
Offline Hugh Currin
  • Box Elder, SD, USA
    • www.currin.us
« Reply #10 on: February 20, 2016, 12:13:22 AM »
Nice tool for setting tool height. Much more accurate than the eye I've always used. After reading this I think I'll make one up pretty soon.
Another cool thing I discovered is that after you've set the tool height , you can rotate the gauge 90 deg away from you, re-square it and jog the tool in or out until it's at zero again & set the offset in Mach3's tool table.  (Or whichever CNC lathe controller du joir you're using).
Briliant. Now I'll have to make one up real soon.
Stan & Dickeybird, thanks.
Hugh
Hugh
Offline phrodo
  • Jr. member
« Reply #11 on: February 20, 2016, 10:53:27 AM »
Hi,
Forgive me if I'm missing something here, but don't the two pictures show a delta of 0.1125 not 0.125?
Offline pgp001
  • West Yorkshire - UK
« Reply #12 on: February 20, 2016, 11:41:49 AM »
Well spotted, you are right. One turn plus 0.0125 is not 1/8", it should be reading 0.025
The principle works though, he probably just had a "Blonde" moment setting it up for the photo.
Phil
Offline sshire
    • LS Editions
« Reply #13 on: February 20, 2016, 01:18:54 PM »
Correct. It was a quick setup for the photo shoot.
Good catch, though.
Best,
Stan
Offline DICKEYBIRD
« Reply #14 on: February 20, 2016, 03:14:44 PM »
Now that the pics are being talked about; is it just the wonky vision caused by my progressive lenses or does the test rod lean upwards?  I hope it's just me. :insane:
